Rear Springs n related bits - Defender Source
Old April 9th, 2011, 12:26 PM
DNinety's Avatar
DNinety
JP
1984 Ninety 200TDI
Thanks to the for-sale section, I've been able to pick up nearly all of the necessary parts for a complete shock/springs overhaul, but I'm missing just a few items. I just thought I'd check to see before placing an AB/Rovahfarm order - seeking relatively 'new-ish' condition:
- OME Rear Medium-Duty Springs (764)
- Rear spring retainers
- Rear spring seats
- Front shock tower securing rings - mysteriously both of mine seem to have a broken bolt
Old April 10th, 2011, 06:03 PM
CDeWan
Clay DeWan
5.3L beastie
I have the rear spring retainers. Front shock tower securing rings but not sure what you mean by rear springs seats?
I'll PM you my phone#
Old April 10th, 2011, 09:54 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Seat is the little metal dish that mounts to the frame and olds the coils into place.
Old April 10th, 2011, 10:21 PM
Oliver Whiting
Oliver Whiting
84 110, 94 NAS90,Bunch of EX-mods
springs
I have two Old Man Emu 764 rear springs sitting on a shelf for several years.
Old April 11th, 2011, 08:57 AM
The Dro
Dro
1988 Ninety
he might be referring to the spring isolator.
http://www.roverparts.com/Parts/ANR2938.cfm
Old April 11th, 2011, 11:01 AM
d90dang's Avatar
d90dang
Matthew
1997 D-90
i have some slightly used OME 762's less than 200 miles on them
Old April 11th, 2011, 11:28 AM
DNinety's Avatar
DNinety
JP
1984 Ninety 200TDI
Manimal is correct: http://www.roverparts.com/Parts/NRC9700.cfm. Mine are still usable but pretty corroded, so will replace.
D90dang: thanks for the offer, it sounds like the kind of lightly used springs I am looking for, but with my setup, the 762's will be too much lift in the rear.
Oliver: I'm just headed to the airport, but if you want, you can PM me the general info - how much use they received, if they are corroded, etc. I appreciate you taking a look here and making them available.
Clay: thanks, I'll give you a call and presuming that the retainers and securing rings are in half-decent shape will take the lot.
4-5" lift springs for rear of RRC Shane@EVS Wanted 0 March 16th, 2006 03:09 AM
rear springs GeoParth Defender Technical Discussions 6 December 22nd, 2005 05:36 PM
Rear Springs Jase Wanted 24 April 26th, 2005 07:31 AM
97 st Stock Springs/ rear bench seat Britt Easterly For Sale - Parts 4 May 29th, 2004 03:08 AM
