rear seatbelt - Defender Source
Old September 27th, 2006, 07:49 AM
rear seatbelt
I need 1 or 2 rear seatbelts - both the long strap with the spool and the short strap with the buckle.
Also could use a few BFG MT 285/75/R16 if in decent shape.
tia
charles
Old September 27th, 2006, 08:50 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
check with Will Tillery in VA the Disco belts will work.
Old September 28th, 2006, 01:47 PM
JasonChristie
Jason Christie
1995 Defender
Charles,
I have 2 rear seat belts available. The buckle on one is servicable but the plastic casing is broken. I don't think I have the hardware for them anymore, but I have both the long belts and the short belt (middle belt) available.
Jason C.
Old September 28th, 2006, 03:12 PM
Thanks Jason, but I ended up getting one from Will Tillery. Hope it's a good match
charles
Old September 29th, 2006, 07:47 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Originally Posted by JasonChristie
Charles,
Jason C.
Hey Jason,
I'd be interested in the rear middle belt for the bench seat. The one I have the plastic release button is broken on one of the buckles. Let me know what you ar asking for it, and what condition it is in...
~Scott T.
'95 D-90 ST - AA Yellow
Old September 29th, 2006, 04:18 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
I'm looking for 2 seat belt kits for inward facing, fold up seats. I believe my seats are Atlantic British as they are aftermarket. I can not find seatbelts short enough to fit them. And again - LR brand are frightfully expensive.
Anyone got something?
Old October 7th, 2006, 12:31 AM
hlamar's Avatar
hlamar
Heston LaMar
97 NAS D90 ST #1789
Hey, I could use the same. Did those from Will work out? If so, how did you get in touch with him? Specifically, I need the male ends of the rear belts for forward-facing rear bench in a 97 NAS soft top.
Heston
Heston
Old October 8th, 2006, 09:16 PM
Actually having some trouble with them. They lock up easily and I can't seem to free them without removing the top mount to allow more belt back into the spool before they release. I have made sure they are perfectly verticle (on the driver's side I had to modify the mounting bracket to do so). I changed the driver's side belt too since they are grey and the original is black. Also, the bottom straps are shorter than the original. I'll play with them some more before giving up though.
charles
Old October 8th, 2006, 10:05 PM
I'm going to use these folks for my replacement front belts. You can custom build a belt online, and they look just like OEM.
http://www.gotbelts.com/products.html/index.html
seatbelt
Rear seatbelt Q's Seanh Defender Technical Discussions 5 December 1st, 2005 08:40 AM
Rear seatbelt removal chrisvonc Defender Technical Discussions 2 February 18th, 2005 04:04 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
