Rear salisbury 4.11 R&P - Defender Source
Old October 8th, 2013, 07:50 PM
Fearnofish's Avatar
Fearnofish
85 110 CSW
Priced them out from lucky and GBR and have a bit of sticker shock. Got to be able to find them less than $600. Let me know.
Old October 8th, 2013, 07:57 PM
If you switch out the end of the rear driveshaft you can run Dana 60 gears. So I am told.
Old October 8th, 2013, 09:19 PM
Fearnofish's Avatar
Fearnofish
85 110 CSW
I've discussed it with a few folks and converting my drive shaft to a yolk end and changing a few other pinion mounting bits will get me there but then I've spent almost as much as new sals gears. I appreciate the suggestions but I'm hoping someone has a set that they tried and didn't like or need and then I'd have a few schmeckles to spend on new bearings. Thanks.
Old October 8th, 2013, 09:31 PM
Ya but used 4.10 Dana 60 gears should be near free right?
Old October 8th, 2013, 09:34 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Schmeckles?
Old October 8th, 2013, 09:42 PM
Fearnofish's Avatar
Fearnofish
85 110 CSW
If that's the case then I welcome some education on the right parts. I have decided on a Detroit locker in the rear so the gears need to fit that diff. Suggestions? Yeah schmeckles... Coins
Old October 8th, 2013, 09:43 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Not that many sals rear ends around in the US realistically so I'd reckon used will be difficult to find. The regular rover gears are $300. So twice as much for the sals gears from GBR. It's probably cheaper to find a different ratio T-case.
You little rebel, I like you.
Old October 8th, 2013, 09:53 PM
Fearnofish's Avatar
Fearnofish
85 110 CSW
That's a good idea too. I've got ashcroft fronts so I'm trying to finish up the conversion. Thanks.
Old October 9th, 2013, 03:11 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Converting to D60 gears maybe close to as much as Sals gears but now your repairs on the diff will be less in the future . I am looking into doing gears on my sals and will be converting to 60 gears .
85 D110 3.5 3 DR
Old October 9th, 2013, 08:44 AM
Fearnofish's Avatar
Fearnofish
85 110 CSW
I'd be interested in hearing your plans, parts and modifications needed. Please share.seems like there are several ways to do this after searching various rover forums.
Old October 9th, 2013, 09:14 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
True. I always wondered where this one ended up...
Rent my
Non Abs rear hubs for salisbury disc o2batsea Wanted 0 June 24th, 2012 05:53 PM
110 axles: salisbury rear and front evilfij For Sale - Parts 9 October 11th, 2009 11:36 PM
Caliper brackets for a rear Salisbury disc brake conversion Tyler Wirken Wanted 0 September 22nd, 2009 12:17 PM
110 salisbury rear axle tommyd Wanted 10 July 25th, 2009 09:39 AM
Rear 3rd Mem 4.75 R&P w/ Detroit orlandog For Sale - Parts 0 April 18th, 2004 01:05 AM
