Rear Loadspace mat - Page 2 - Defender Source
Old January 18th, 2013, 10:38 AM
bjf's Avatar
bjf
barry f
94 ST #395
I bought one from rn a few years ago and it split on the seam within months.
Old January 18th, 2013, 10:40 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
So it seems no matter where you get these, they are dried out and split easily...any better alternatives? I have a dried out torn one now so would make no sense to pay $200+ for another.
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old January 18th, 2013, 10:44 AM
How split is it? Only along the seam? You can try to experiment with the roofing adhesive I was talking about on the other page. Take the mat out, lay it flat with the back facing you, lay the adhesive material down in a single 6" wide strip down the seams, or get some rubber pond liner and a strong adhesive and run the adhesive down either side of the seams and then lay the pond liner down on top of it. It should help keep it together, and you may not really be able to tell once you flip it back over.
Like this
http://www.pplmotorhomes.com/parts/rv-roofs/41347.htm
Old January 18th, 2013, 10:53 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Like this
Mine is torn all the way down on the fender well sides front to back on left and right side. It is just drooping and hanging now. Plus I don't think it could fade anymore. I will just replace and hope I get one that is not dried out.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old January 18th, 2013, 10:55 AM
bjf's Avatar
bjf
barry f
94 ST #395
I wouldn't say they come dried out. It's just they are thin on the seams. Next one I will run duct tape on the back along the seams.
Old January 18th, 2013, 11:05 AM
willhahn24
William
1995 D90 SW #450
Originally Posted by SMac View Post
Yeah, it is the one that covers the wheel wells that are for the STs. I planned on cutting it up to fit my SW on top of soundproofing and Dynamat. The only concern I had was the durability as mjekogian pointed out, which I guess is common with these mats. A lot of folks recommend going a different route unless you don't use the loadspace for hauling much.
I've been meaning on doing the same and am wondering if its better to buy the OEM ST and cut it for the SW or the Exmoor 3 piece kit, anyone have any input on the Exmoor kit?
Old January 18th, 2013, 11:08 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
For a new mat from RN, I ran Gorilla tape on the backside of the seams (to reinforce) and a healthy bead of black silicone caulk around the perimeter (attempt to keep it dry and "glued" down) and a few lines on the verticals (attempt to keep the weight off the seam). So far so good, but it has only been a year.
Old January 18th, 2013, 11:11 AM
Yeah it definitely needs something on those seams - Gorilla tape is probably a good choice as well and definitely cheaper than roof adhesive sheets.
Old January 18th, 2013, 11:31 AM
Go to your local Tractor Supply. Out in the yard area they have what are called "stall mats", which are thick sheets made of recycled rubber. Get one that's 4x6 and trim it to fit the rear deck of your truck. It will cost you like $45 and you will never have to be worried about the load space again. It won't have a spiffy logo molded in, tho....
Old January 18th, 2013, 11:53 AM
gambrinus
Russ Wilson
1965 Dormobile
As Bill just said... Go to your local farm and ranch store.. look for Stall Matting.
Here is a link to a place with a standard 4' x 6' x 1" thick piece... $24.
http://www.therubberman.com/ortho-foam-stall-pad.html
Since you are in Denver, just go to Murdoch's on Santa Fe.. just south of the 470.
This is what I've used for 20yrs. Cheap and You can NOT kill it... it's designed for horses to STAND on.
only downside is that you don't have your wheel wells covered with one solid piece. I've always used the thinner stuff that they have on rolls and just have it UNDER the big center piece to hold everything in place.
Old January 18th, 2013, 12:09 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
Link mat. Doesn't trap moisture, and if it rains on your camping gear with the top off, your camping gear isn't sitting in water.
http://www.lyndist.com/mats/entrance_mats.htm
Old January 18th, 2013, 12:31 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
I put black gorilla tape on the seams of my 90s mat where it was tearing and it held together fine maybe i should run some on the back of the new mat to keep it from tearing
Old January 18th, 2013, 04:46 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
I was looking at that Exmoor 3 piece acoustic loadspace mat, my only reservation was that it looked unfinished/rough on the trail edge that faces the rear door. I would love to see a pic from someone whos installed one.
Old January 19th, 2013, 01:15 PM
RayME
Ray S.
'73 SIII 88
If you are up for an non-LR option that is inexpensive, kills road noise and dampens panel vibration, try a $39 Tractor Supply stall mat. This thing is 3/4" thick rubber and bullet proof (or at least resistant...).
Old January 25th, 2013, 12:02 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Called the number and it turns out it is the parts website store for Lakeside Jag/LR dealer in Macomb Michigan. Might be a good source for decent prices on Genuine parts. I'll be the guinea pig I guess....
Sam did you get your rear mat in from that dealer in Michigan? How did it look?
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old January 26th, 2013, 07:54 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Matt, I did not. Im on the fence between this mat and the Exmoor. I'll do up the rest of the trucks interior including the front Exmoor matting kit and then decide.
Old January 31st, 2013, 10:57 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
So I tore this old piece of shit out yesterday, and have decided I want a OEM mat just like I had. Anyone bought one of these recently, as in the last few months from BP or RN that can confirm that they got a good one, not dried out? Wanting to place order for mat soon. Thanks in advance.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old January 31st, 2013, 11:26 AM
Cut off the sides and clean up the base, and you could probabl sell that remaining piece for $20+ shipping. It's incredible the things people will buy here.
Old January 31st, 2013, 11:35 AM
bjf's Avatar
bjf
barry f
94 ST #395
They are never dried out. These things are still made. Not old stock. The issue seems that whoever makes them for rover now doesn't make them to the same high standards as they used to be. The sides typically split after a few months. Just run tape down the back and it will hold better.
Old January 31st, 2013, 12:14 PM
SafariHP's Avatar
SafariHP
Safari Heritage Parts
1983 Defender 110
Another option is the single piece Exmoor load space mat:
http://www.exmoortrimusa.com/model/d...rear-load-mat/
2450 North Forsyth Rd
Winter Park, FL
(407)517-4983
ac
90 Rear Loadspace Rubber Mat ddrotts Wanted 1 June 9th, 2009 11:09 PM
FS used D90 soft top rear cargo mat ECR For Sale - Parts 4 May 5th, 2009 08:11 AM
97 D-90 Rear Bench Seat, Belts, Cargo Tub Mat wadaman For Sale - Parts 7 February 24th, 2009 11:58 PM
WTB D-90 Rear Loadspace Mat, Light bar wadaman Wanted 1 February 6th, 2009 06:03 AM
Disco rear floor mats & cargo mat BECFA For Sale - Parts 2 August 17th, 2008 10:32 AM
