Rear brake line - Defender Source
Old May 31st, 2015, 09:09 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Rear brake line
Anyone have a left rear brake line off of a Salisbury axle? At the very least I just need the fitting off of it as mine is stripped. Can be a brake line off of a 90 as well. I have 90 rear calipers on the axle and ultimately just need the fitting that screws into the caliper.
Tyler
Old June 1st, 2015, 08:21 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Great place to get fittings & line…. Fedhill brake line - Where to buy brake line, fuel line, brake line flaring tools, brake line nuts and brake line fittings
I may have a spare fitting in my kit if you don't want to order from Federal.
Old July 28th, 2015, 08:43 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Back to the top -- Fedhill looks like a great resource, but does anyone know the specific tools, line and nut size I would need for the front rigid lines on a non-abs rrc?
Old July 28th, 2015, 01:22 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
3/16'' line, M10x1 fittings.... You're talking about the hard lines at the caliper right? IIRC those lines use a bubble flare on the male end & a double on the female end. I used lines from Napa with bubble flares, cut one end & double flared the cut end.
Old July 28th, 2015, 03:20 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I bought one of these years ago:
Professional Brake Pipe Flaring Tool
Use it with this type of line:
http://www.amazon.com/AAS-Copper-Nic.../dp/B00651OAVS
RDavisinVA
Old July 28th, 2015, 03:51 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Thanks, this is for one of the two lines going from the MC to the left front caliper.
Old July 28th, 2015, 04:15 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Those are 10x1... one male & one female. You could probably reuse your fittings.
Old July 28th, 2015, 04:22 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Excellent, thanks. Is there a usable bubble flare (that's the right flare, right?) tool for use a handful of times?
Old July 28th, 2015, 04:27 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Fedhill has a rental that looks very similar to Rob's. But for one line I'd do what I suggested above and the loaner flaring tool from AutoZone worked fine for a double flare needed on the female end.
Or you could invest now in a tool and do all your lines before one springs a leak.
Old July 28th, 2015, 07:33 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I have a bench tool, but I've been thinking of getting one of these to keep in my tool box.
Automotive Bubble Flare Kit No. 155 | VehicleServicePros.com
Looks like they run about $20
http://www.tooldiscounter.com/ItemDi...mRThoCMpvw_wcB
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
brake
Front brake line - why hard line & flex line? jefhuf Defender Technical Discussions 5 January 13th, 2012 09:03 AM
110 rear brake line Tyler Wirken Defender Technical Discussions 6 March 28th, 2010 11:04 PM
Quick question, let's say you lose the rear brake line on a D90, is it dual circuit? evilfij Defender Technical Discussions 8 July 21st, 2009 08:05 AM
Rear Brake Line 1of40 Wanted 1 January 3rd, 2008 01:49 PM
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
