Rear bench seat belts. - Defender Source
Old May 30th, 2007, 07:41 PM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
PO says he never had the center belts for the bench (shoulder belts are installed, go figure). Anyway, I need a set so I can reinstall the rear bench.
Please email me at scott.yates@gmail.com . Need as soon as possible.
Some people are like a slinky... not really good for anything, but you still can't help but smile
when you shove them down
the stairs.
Old May 30th, 2007, 09:35 PM
It appears that the bracket that holds the two center belt receptacles between the inward facing jumpseats is the same one that holds the receptacles for the forward facing bench - the only difference I think is length.
Since inward-facing parts are easier to source, perhaps you would be successful by simply buying one of the inward facing pieces and having them lengthened by Ssnake-oyl (a seat belt refurb company).
Old June 3rd, 2007, 04:25 AM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
Still looking.
the stairs.
Old June 3rd, 2007, 10:48 AM
Best4x4's Avatar
Best4x4
Kelly Graham
P38
Hey Scott you can use Range Rover classic front seat belts and the "Y" strap front the rear seat.....It cheap and really easy to find....The only problem is that the "Y" belt is about 2 to 3 inches shorter than the D90, but you can still buckle it.....I'm using this same setup in my 90 now....Good Luck....KG
Old June 8th, 2007, 09:51 AM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
Thanks for the suggestions. I have been looking but have been unable to find the suggested vehicle in the area so I am still looking.
If you can help, please email me at scott.yates@gmail.com
the stairs.
Old June 8th, 2007, 11:17 AM
pcscharfe
pcdefender
D90/NAS 110
Scott,
I believe the part you are looking for is STC3178 "Center Seat Belt Rear Assembly" -- I sourced one form Stephen Peters here on the forum and was quoted $210.00 . I passed, because I was able to live with mine in it's slightly damaged condition. Check this thread, and drop him a line.
http://www.defendersource.com/forum/...ead.php?t=9200
Old June 9th, 2007, 07:23 PM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
I am hoping to find one of you single guys that is pulling the rear seat anyway. I am considering pulling the rear belts from a Jeep CJ if I can't locate something suitable soon.
the stairs.
Old June 21st, 2007, 03:47 AM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
Still looking. $210 is a bit more than I wanted to spend. I will go that way if I don't here something soon.
the stairs.
Old June 21st, 2007, 09:52 AM
Scott, the Y belt from a disco works too. Also a few inches short, but still workable. Try Will Tillery if you can't get them local. He can get them for you cheap.
charles
Old June 22nd, 2007, 03:08 PM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
Charles,
I tried using a search for Will Tillery and could not find any matches. Do you have contact information for him?
-Scott
the stairs.
Old June 22nd, 2007, 03:15 PM
Here is his user profile
http://www.defendersource.com/forum/members/willtillery-324.html
I'm not sure if these are current, but I have 2 numbers for him
434-251-9331
877-580-1950
hth
charles
bench
Side Brackets for Rear Bench Seat & Rear Seat Belts zed111 Wanted 2 August 16th, 2004 12:33 PM
Side Brackets for Rear Bench Seat & Rear Seat Belts zed111 Defender Technical Discussions 2 August 13th, 2004 05:33 PM
Rear Bench Seat Belts boshea For Sale - Parts 5 July 7th, 2004 05:07 PM
Seat belts for forward facing rear bench seat bd90 Wanted 9 June 5th, 2004 07:24 PM
