Rear Axle/Hubs - Defender Source
Old August 9th, 2016, 12:24 AM
ShoreRover's Avatar
ShoreRover
Brandon Sherwood
'91 110 5dr
Rear Axle/Hubs
In need of a complete rear discovery axle or a good place to source the hubs.
Was in the process of replacing the wheel bearings over the weekend and discovered the hubs were pretty beat up.
Old August 9th, 2016, 01:10 AM
ShoreRover's Avatar
ShoreRover
Brandon Sherwood
'91 110 5dr
Old August 9th, 2016, 01:12 AM
ShoreRover's Avatar
ShoreRover
Brandon Sherwood
'91 110 5dr
Will take a few others from the other hub, which looked more beat up then this one.
Old August 9th, 2016, 09:47 AM
Paul Grant
Paul Grant
I have three DI's and a '95 RRC here in the yard. They all have complete rears. If you're still looking for parts let me know what you need, I'm sure I have it.
Paul Grant
203-770-1699
Old August 9th, 2016, 10:29 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
You trying to start a fire under your truck? For the love of all things holy buy a set of jack stands!!!
Old August 9th, 2016, 10:45 AM
Paul Grant
Paul Grant
I send you my email and details for the hubs and new rotors I have on hand.
Paul Grant
203-770-1699
Old August 9th, 2016, 10:54 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Why not just replace the races and bearings?
Old August 9th, 2016, 10:56 AM
yeah, there's nothing on a hub that wears out beyond the seals, races, and bearings.
Old August 9th, 2016, 11:02 AM
ShoreRover's Avatar
ShoreRover
Brandon Sherwood
'91 110 5dr
I agree with the jack stands, they are on my list!
I had intended to do the races bearings and seals but looking at the condition of the of the inners of the hubs I felt safer to replace the hubs then have an issue down the line.
------ Follow up post added August 9th, 2016 11:02 AM ------
Thanks Paul , can you PM me the total and I get it right out.
Old August 9th, 2016, 11:03 AM
Sorry Brandon....what's wrong with the inners of the hubs? I don't see anything in the photos that looks particularly untoward?
Trying to save you money here.
Old August 9th, 2016, 11:39 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
The spindles are replaceable too but should be OK to reuse as long as the surface where the bearing rests is not heavily worn and the seal mating surface is in good condition.
Old August 9th, 2016, 11:49 AM
ShoreRover's Avatar
ShoreRover
Brandon Sherwood
'91 110 5dr
Im probably being over cautious, but Paul had complete rebuilt hubs with new enough rotors already attached so I decided to go that route will keep these as spares unless someone has interest. And I will keep my rebuild kits for the fronts when I decide to do the front axles.
Thanks for looking out..:-)
Old August 9th, 2016, 02:06 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I actually feel safer working under cut and stacked 6x6 timbers. Jack stands scare me!
axle
Pics of HD rear axle vs stock axle? josh-man Defender Technical Discussions 22 July 4th, 2017 04:22 AM
Rear hubs and spindle axle on 94 NAS D90 BrianKelley Defender Technical Discussions 5 October 12th, 2015 10:17 PM
Non Abs rear hubs for salisbury disc o2batsea Wanted 0 June 24th, 2012 05:53 PM
1997 D-90 rear axle housing and 83' 110 front axle housing Tyler Wirken For Sale - Parts 0 January 3rd, 2012 06:31 PM
Series III Rear Axle (Drum-to-Drum or Axle Housing) Lriwater Wanted 0 September 7th, 2009 08:08 PM
