RD953066 resistor - Defender Source
Old August 20th, 2010, 11:34 PM
RD953066 resistor
Any idea where I can buy a RD953066 resistor (6.8k ohm)?
Charles
Originally Posted by pendy
I'm here for the D's
Old August 21st, 2010, 07:35 PM
If you know the wattage ... radio shack!
Old August 22nd, 2010, 09:39 PM
You mean the resistance? It's 6800 ohms. I guess I'll try them.
None of you guys parting out discos have any of these they could yank off a truck?
Old August 22nd, 2010, 10:00 PM
madcowdungbeetle
Carter
whats it look like, i may have one?
Rugbier's Avatar
Rugbier
Gustavo
Contact Randy Williams or Trevor ( Roverlab )
pm inbound with Randy's #
NO SIGNATURE
Resistors will have a resistance in Ohms and a rating in watts ...
if in doubt just get a big one!
Old August 22nd, 2010, 10:10 PM
Thanks Jason - no idea on the wattage.
Thanks Gustavo. Will call Randy if Carter doesn't have one.
Carter, it's in the wiring harness going to the MAF, usually taped on the outside. White wire with black strip and a little black plastic rectangle with spade connectors on it.
http://www.defendersource.com/forum/...1&d=1282529273
Old August 22nd, 2010, 10:53 PM
The Dro
Dro
1988 Ninety
Charles,
I had this in my bookmarks (when I was trying to fix the rrc).
http://www.britishv8.org/Articles/Rover-14CUX-EFI.htm
That's called a tune resistor... try contacting RPi
Old August 22nd, 2010, 11:43 PM
madcowdungbeetle
Carter
I should have you covered Charles shoot me your address.
Old August 23rd, 2010, 06:20 AM
The Dro
Dro
1988 Ninety
I take this back... I was reading the document and just realized that I gave you the wrong info.
RD953066 is an Engine Speed sense circuit.
Old August 23rd, 2010, 07:56 AM
Thanks Carter!
Pedro, see my no start thread - way ahead of you.
Old August 23rd, 2010, 08:02 AM
C, the engine speed sense should be something like 5volts. I should think a 10 watt 6800 ohm resistor will do the trick. Go to digikey.com and look on page 1966 of the catalog.
Old August 23rd, 2010, 08:49 AM
The Dro
Dro
1988 Ninety
Thanks Carter!
I'll shut-up from now on...
Old August 24th, 2010, 12:42 AM
madcowdungbeetle
Carter
Charles, send me your address, or do I just address it to "Charles Galpin, the man, the myth, the legend" and the USPS will know where to deliver?
Old August 24th, 2010, 07:28 AM
Yes this usually works.
Just kidding. I sent an email via the site - I guess you didn't get it? I'll resend and via PM as well.
Thanks again.
charles
Old August 29th, 2010, 09:24 PM
Carter, I never heard back from you - did you get my PM and/or email?
Old August 30th, 2010, 01:02 AM
madcowdungbeetle
Carter
Yea I got your PM, sorry it turned into a hectic week here with everything going on. Your resistor will be in the mail tomorrow. My apologies for being a slack-ass.
Old August 30th, 2010, 08:33 AM
madcowdungbeetle
Carter
Boy do I feel like as ass.
OK, the Disco I have here does not have one of those. I just went to yank it off the truck only to find it does not have one, or the even the provisions for one. I stripped the MAF harness all the way back to the engine harness... notta.
If you can PM me who has one, I'll order one for you while I'm at work today and get it headed your way. Again sorry for being a slacker.
Old August 30th, 2010, 08:41 AM
No worries man - I appreciate you looking. I'll try Randy.
Old September 1st, 2010, 06:39 AM
d110pickup
Mike Pado
'97 D90 ST #1153
I got one from RN a couple of years ago, cost about $14.
I've found them on '88 & up RRC taped to the wiring harness a couple of inches from the plug into the computer.
In '87 they were attached to the wire at the coil, after that they were moved. I had a very annoying & persistent intermittent problem. That resistor was the culprit.
Good Luck!
NAS 110 Blower Motor Resistor rogersta Defender Technical Discussions 1 November 17th, 2009 06:05 PM
Funky Flasher JBfoot Defender Technical Discussions 6 April 5th, 2008 11:33 AM
Issue with Exhaust - It STINKS Literally hutch Defender Technical Discussions 43 January 23rd, 2007 08:50 AM
NAS spec D90 tune resistor help required UKlandyandy Defender Technical Discussions 8 May 7th, 2005 07:05 AM
Wiring help TDI Guy Defender Technical Discussions 2 October 1st, 2004 01:03 PM
