radiator for 1989 Defender90 - Page 2 - Defender Source
Old February 11th, 2015, 03:10 PM
TedJan
Ted Jancewicz
none
D90 radiator
Happy to say the radiator,Esr 78,was a perfect bolt in fit.Safari HP a delight to do business with.Thank you for the reference.
Radiator was replaced for major leaking.However there is still issues with the cooling system that I am going to defer to a diesel specialist.Expansion tank immediately overflows after running a minute and there is a lot of pressure and turbulence in the tank.Tank eventually drains itself. Engine doesn't overheat and actually never gets beyond 140f despite a new thermostat.Peculiarities include temp guage cycling between normal and almost hot for the first 10 minutes if running and then settling down to normal.Also,no hot air from the heater for about the first 10 minutes and then you get heat(very hot)if you hold the throttle past 2000 RPM's.I'm thinking head gasket but I am a novice when it comes to diesels.
Thanks again!Ted
Old February 11th, 2015, 03:14 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I will note that 140C is 100% overheated.
Have you done a pressure test?
Old February 11th, 2015, 05:20 PM
TedJan
Ted Jancewicz
none
defender radiator
My mistake.140F.Post has been corrected.Thanks
90, defender, defender90, radiator
Defender90 :: 1994 Land Rover Defender 90 Sam401 Defender & Series Truck Registry 0 May 31st, 2014 01:43 PM
Repair/ Body Shop for Defender90 Sam401 Defender Technical Discussions 3 November 21st, 2013 10:23 AM
Front and back Passenger side speakers not working on 97 Defender90 Dfender97 Defender Technical Discussions 1 May 21st, 2013 07:14 PM
95 defender90 for sale Ray Bone For Sale - Vehicles 7 November 28th, 2007 10:40 PM
