Radiator bleed plug . . . Need help - Defender Source
Old September 7th, 2015, 09:58 PM
wanabewheelin's Avatar
wanabewheelin
Michael Sword
1989 110 200TDI, RHD
There I was on the sudo home stretch of an engine pull, had just put the radiator in and tightened the hoses up. Oil lines were snug and I figured it was almost time to start adding some fluids. Topped up the oil, even managed to make sure the drain plug was tight. Then I went and took off the bleed plug for the radiator, or attempted to . . . Snapped clean off, plastic piece of junk. Managed to get the other end out, but anyone have an idea of where to get one quick, besides canabalizing one off Pedro! The wife would seriously like her car back, LOL
Old September 7th, 2015, 11:42 PM
Its a standard npt but cant recall size. Might find a brass plug at home improvement or hardware store in a pinch. Get a brass. Everyone needs to get their plastic plugs replaced. Those plugs are made from head gasket failure plastic.
Plastic radiator plugs are #2 on the "WTF were you Rover engineers thinking" list.
Mark Kellgren
KM4BOR
Old September 8th, 2015, 12:22 AM
Ignotus
gene
1960 109, w/200TDI
Just go to you local radiator repair shop, I got one free at mine.
Gene
1960 109
1960 88 Ignotus
Blog;
Old September 8th, 2015, 05:26 AM
Ditching plastic crud should be listed right after ditching old oil cooler lines
At under $4 must be one of the cheapest parts at RN.
But free is best
Old September 8th, 2015, 05:30 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I'm pretty sure they BSPP and not NPT, though you can force a NPT plug in as the threads are similar. Trevor at Rovahfarm has the proper BSPT brass ones for $3.50. And he ships priority USPS.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 8th, 2015, 06:27 AM
Originally Posted by Antichrist View Post
I'm pretty sure they BSPT and not NPT, though you can force a NPT plug in as the threads are similar. Trevor at Rovahfarm has the proper BSPT brass ones for $3.50. And he ships priority USPS.
If you're pretty sure then go with that. I cant remember exact thread but knows it's pretty standard.
Mark Kellgren
KM4BOR
Old September 8th, 2015, 09:08 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Do not put a tapered pipe plug in it's place, you'll chew up the straight threads.
You can buy a solid brass replacement from RN which is the only way to go.
Good Luck.
RDavisinVA
Old September 8th, 2015, 09:12 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Good Luck.
You're right, it's BSPP, not BSPT. Unfortunately I can't go back and fix my mistake, which sucks, especially since I posted Trevor has the wrong plug thread.
The new radiator I got a few years ago actually came with a brass plug, but I just went down and tried one from a Disco 1, which I know is BSPP, and it's the same thread.
I'm pretty sure they BSPP and not NPT, though you can force a NPT plug in as the threads are similar. Trevor at Rovahfarm has the proper BSPP brass ones for $3.50. And he ships priority USPS.
Fixing my post as best I can.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 8th, 2015, 09:14 AM
Don't over tighten and crush the oring either. I always pressure test mine after install to make sure they aren't leaking.
Old September 8th, 2015, 09:37 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I can't go back and fix my mistake, which sucks, especially since I posted Trevor has the wrong plug thread. Fixing my post as best I can.
Tom you're cool.
Everyone makes mistakes, even UD...
RDavisinVA
Old September 8th, 2015, 09:55 AM
Tom you're cool.
Hey Now !
See signature line....
Old September 8th, 2015, 10:24 AM
Is -1
Old September 8th, 2015, 10:35 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Get the RN one. Dont forget to get a new oring. $8 for both.
Or $3.89 for both at Rovahfarm. Or $3.95 if you use the aluminum sealing washer instead. http://www.rovahfarm.com/defendercoolingpage2.htm
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 8th, 2015, 10:55 AM
I've got some plastic ones you are welcome to. That'll get you on the road for the two days until your brass ones show up. Or just find a rubber expand-o plug from your FLAPS.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old September 8th, 2015, 11:37 AM
WASHER RADIATOR FILL, RNC996, ERR4685 - Rovers North - Classic Land Rover Parts
f
They also have a 50 cent o-ring. It is just an o-ring.....
O RING RADIATOR FILL PLUG OR D2 DIFF FILL PLUG PLC997 OR RNC997, PLC996, ERR4685. - Rovers North - Classic Land Rover Parts
Old September 8th, 2015, 11:43 AM
You can't hurt the o-ring by tightening too much. The o-ring has a containment groove. The o-ring compression is set by the sizing of the groove. Tightening more or less will have no effect on whether it seals or not.
Old September 8th, 2015, 11:46 AM
I get replacement orings for my brass plug from napa. They hv the right size in stock usually in their little oring selection box. Good item to hv in your spares
Mark Kellgren
KM4BOR
bleed, radiator
Clutch does not engage - do I need to bleed? sro Defender Technical Discussions 18 January 2nd, 2013 11:28 PM
Rear brake caliper stuck / won't bleed nathanwind Defender Technical Discussions 3 March 16th, 2012 08:25 PM
Expansion tank bleed hose trybul Defender Technical Discussions 0 December 5th, 2011 02:26 PM
Clutch Slave cylinder bleed?? Quimbola Defender Technical Discussions 2 February 10th, 2009 11:17 PM
Calipers and Bleed valve jabber Defender Technical Discussions 4 December 22nd, 2004 11:54 AM
