Power Steering Pump - Defender Source
Old August 29th, 2014, 02:52 PM
COJ142's Avatar
COJ142
Michael Giroux
1985 Defender 110 CSW RHD
Power Steering Pump
Fellas. Any input on source new pump to replace PAS?
Rover's North has one Part # Plh245 for $359.00 but I'm wondering if anyone's had any experience. Reason I ask, is mine was replaced 4 months ago and it's gone again. If there's an upgraded one or one I should steer clear of (no pun intended) appreciate the head's up.
BTW- it's for a Defender 200TDI RHD
As always, THANKS!
Old August 29th, 2014, 03:49 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
For some reason and who knows why, the 200TDI PS pumps fail fail fail.
I have had bad luck with them on both the defender and Disco engines.
I made a prototype bracket to install the Mercedes PS Pump on the Disco 200TDI and it was a huge success.... that's the good news.
The bad news is that I have not conquered the 200TDI Defender pump because I don't have a 200TDI vehicle handy. They are rare in this country.
I think there is a new one on the workshop shelf that cost at least $300.
If that will get you out of a bind. You could take it at cost + shipping.
Will need to look at the fittings to be sure it is an exact match with your hoses.
RDavisinVA
Old August 29th, 2014, 05:06 PM
My solution for the failed Tdi pump was to use one from my gaggle of Range Rover Classic stash. Trick is you will have to change the pulley fitting. It is a press fit on the shaft, so you need to have a shop remove the one from the bad pump and put it on the RR one.You'll also need to reconfigure a low pressure return as the Tdi one is on the side and the RRC one ends up pointed down at the road. I made one from copper plumbing parts, which works but isn't too elegant.
You should be able to find a RRC pump for very small money.
Old August 29th, 2014, 05:13 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Bill do you have a 200TDI Disco or Defender style engine.
The PS pumps among the 200TDI Defender and Disco are different.
RDavisinVA
Old August 29th, 2014, 05:57 PM
To my knowledge on all of these the only difference is where the ports are. Maybe the pulley flanges are different, but they don't seem to be. For the record I had a Disco flavor pump, but the RRC one is on there doing duty now.
Old August 29th, 2014, 07:24 PM
kun109
matt kunert
1975 series III 109
I've got one laying around after converting my series. You're welcome to have it if it helps you out, and it's out of a defender. Still has the hoses attached. If it's something you want fast, like tomorrow, give me PM and maybe I can meet you half way some where, I'm in MD. Matt.
Power Steering Pump dimcon Defender Technical Discussions 11 April 9th, 2007 08:34 PM
95 d 90 power steering pump Needed Scott 9835 Wanted 2 November 28th, 2006 12:56 AM
Power steering pump johnnyg15 Wanted 0 August 16th, 2006 05:32 PM
D90 Power steering PUMP WhiteD90 Wanted 1 February 1st, 2005 12:09 PM
Vendor for Power Steering Pump Pulley wheel ? norros Defender Technical Discussions 0 January 19th, 2005 04:12 PM
