Portals - Defender Source
Old April 30th, 2015, 07:42 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Talking Portals
I am looking to start putting together the parts for a 100 inch build trayback. I would really like Portals but the prices I have gotten for the bolt on style is pretty high. If anybody has a set Unimog, Volvo or bolt on that they want to let go cheap let me know. Thanks
Old April 30th, 2015, 09:13 AM
BRAB
Brandon
200TDI in a RHD 1986 D90
Yeah the Tibus ones are about $9500 for a set. Crazy
Old April 30th, 2015, 09:55 AM
Capt Milks's Avatar
Capt Milks
Yea, my thought exactly. It would be nice to get the lift they provide however, but not for 10 large.
Old April 30th, 2015, 10:33 AM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Anything that hasn't been engineered as a bolt-on solution is going to require extensive fab and machine work to adapt to a Rover housing...sometimes it's just worth the coin to save yourself from re-inventing the setup.
As for axle swaps, keep in mind that the reduction at the box is much greater on a 404 Mog axle at 2.13:1 (compared to Tibus' 1.6:1 or 1.16:1), and you're married to a 3.54 diff so you're really going to be hurting if you want to drive the truck any distance. Just with some quick calculations, at 60mph on 36's you're turning 4600rpm.
-Ash
Geared Restoration Co.
352-572-3236
Old April 30th, 2015, 10:45 AM
rovertrader's Avatar
rovertrader
Dale
Don't underestimate the myriad of additional issues Portals create- up travel, steering geometry, oil pan clearance, etc, etc
Old April 30th, 2015, 10:47 AM
the rover shop
shayne young
Don't tell rhino 130 about the problems....he's been there already...I drool over that truck..
Old April 30th, 2015, 12:04 PM
Volvos are the way to go but they are hens teeth.
Old April 30th, 2015, 12:47 PM
Capt Milks's Avatar
Capt Milks
I know there are other ways to get 37's under the truck but ......
Old April 30th, 2015, 02:11 PM
supercharged67gt's Avatar
supercharged67gt
Andy
64 series IIa x3
I know how to fit 37s under one...
Old April 30th, 2015, 02:16 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Eddie A has 37s on his
Old April 30th, 2015, 03:43 PM
MudD1's Avatar
MudD1
Jeff
Hippert's 1994 D90
38's on a 15x10
Old April 30th, 2015, 04:12 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by MudD1 View Post
38's on a 15x10
Damn, those don't rub on the fender flares?
Love how it looks - and I thought 35's were big on a Defender.
Old April 30th, 2015, 04:25 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
Yes you do Andy
Unknown Author
716-898-8153
Old April 30th, 2015, 04:43 PM
phoenix37's Avatar
phoenix37
john
in action at the 20:33 mark of this video.
Old May 1st, 2015, 08:21 AM
MudD1's Avatar
MudD1
Jeff
Hippert's 1994 D90
Sorry to hijack thread.
38's on a 15x10
Thanks,They are "snug" at 35 psi but aired down to 3psi they only measure about 34"
Jeff
Old May 1st, 2015, 08:26 AM
Ash's Avatar
Ash
Ash Heller
Yeah, it looks tight. I test fit a set of 37's on a recent build and it was just too much tire for a 90 in my opinion. Did you have to shorten your sliders for clearance when turning?
Mike, what's your planned use with this 100"? Unless you need crazy diff clearance I'd be focusing more on making the suspension work.
-Ash
352-572-3236
Old May 1st, 2015, 08:45 AM
Capt Milks's Avatar
Capt Milks
Ash, I am converting the 90 to a tray back. The problem I see with modifying the suspension is you start to get too tall. I want to keep the overall height as low as possible. I understand i am going to have to modify the fenders. More like a high fender kit on the JK. I have some Dana 60's I can use but portals would be so nice.....
Old May 1st, 2015, 09:07 AM
Ash's Avatar
Ash
Ash Heller
Not necessarily...usually what I see with excessively tall trucks is that guys jack them way up in an effort to keep their tires out of the body, but setting your bumps up correctly can allow you to stay low and save you from needing to cut, if that's a concern. Not to mention, the wheel openings on these trucks are massive if you get rid of the flares altogether.
Link it, set your bump to around 5-6", and keep it low. You ought to be able to run 37's, and you can 100% run 35's with 2-3" in height over a stock truck.
-Ash
352-572-3236
Old May 1st, 2015, 09:16 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I've seen you wheel Capt Milks; you don't need portals for those fire roads....
Rent my
Old May 1st, 2015, 09:34 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Roost!
Should be more footage of those 2 rigs (the blue 90 and your Series)
------ Follow up post added May 1st, 2015 09:40 AM ------
Originally Posted by Ash View Post
Not necessarily...usually what I see with excessively tall trucks is that guys jack them way up in an effort to keep their tires out of the body, but setting your bumps up correctly can allow you to stay low and save you from needing to cut, if that's a concern. Not to mention, the wheel openings on these trucks are massive if you get rid of the flares altogether. Link it, set your bump to around 5-6", and keep it low. You ought to be able to run 37's, and you can 100% run 35's with 2-3" in height over a stock truck. -Ash
Totally agree.
Have you guys read Mieser's flat fender build on Pirate? Or seen it on last year's UA vids? It goes right along with the above thought process and tells how capable that little Jeep was.
Rover bolt-on portals...why always after the swivel? sonoronos Misc. Chit-Chat 6 November 24th, 2013 03:34 PM
Mog 404 Portals on ebay D90user The Flea Market 0 September 16th, 2009 08:56 PM
Why not Portals? gtg067i Misc. Chit-Chat 56 December 3rd, 2005 10:58 PM
Portals! Bowtracer Misc. Chit-Chat 7 November 13th, 2005 12:00 AM
