plastic window stud sleeves - Defender Source
Old October 22nd, 2004, 05:42 PM
jstrong98's Avatar
jstrong98
Jon Strong
I need two plastic window stud sleeves for soft top sliding-windows.
Or a replacement part idea ??
JS
Old October 22nd, 2004, 06:05 PM
No you don't. Throw them away and buy some slainless steel studs! The factory ones are *&%$!
Old October 22nd, 2004, 07:00 PM
4WD-90's Avatar
4WD-90
Christopher Stanish
1994 defender 90
Smile
Jon, You could buy some small tubing/fuel line etc. Just cut it in 3" pieces and jamb it on to the studs. I used a deep socket to tap the tubing all the way down on to the studs. Try 1/2" O.D,3/8" I.D. clear fuel line. Much cheaper than those stainless steel studs. I have now had my 90 for 5 days, its awesome!
Old October 22nd, 2004, 09:39 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Christopher, congrats on your new 90!
I agree with Dave, ditch the sleeves. Even aftermarket fixes are just a pain in the ass. When the door top has been on a few months, it is a bitch to get off. I had SS Studs and quick nuts and I am a cheap bastard--that said, I would do the SS again (assuming that you will take yours on and off fairly often as I did).
Old October 22nd, 2004, 10:24 PM
If you "cheap out" and use those stupid plastic sleeves you will eventualy have a real hard time taking your windows off. It is cheaper in the long run to ditch what you have and buy the SS studs. Trust me, do a search and see the hell some fellow D-90ers have gone thru trying to get their windows off.
Window removal Thread
window
Disco II LHD Driver Window regulator or Plastic bushing JohnsD90 Wanted 1 July 10th, 2009 11:33 AM
FS: SoftTop window stud sleeves mpodgorski For Sale - Parts 2 August 18th, 2008 06:40 PM
S/S Window Stud Frustration chris snell Defender Technical Discussions 7 December 5th, 2005 09:16 PM
Plastic parts from driver side window?? Vadim Defender Technical Discussions 1 January 18th, 2005 03:06 AM
Plastic Window Sleeves Glenn_Guinto Defender Technical Discussions 12 June 2nd, 2004 01:46 PM
