Plastic "Capping" - Defender Source
Old May 8th, 2012, 11:16 AM
cthoekenga's Avatar
cthoekenga
1997 BRG D90
Plastic "Capping"
WTB: Plastic "capping" for a 1997 NAS ST that runs the length of the "storage bins" under the dash board. It's about 3 feet long and rounded at the top. My apologies for my ignorance of the correct terminolgy. Thanks in advance.
Old May 8th, 2012, 11:20 AM
safarihp had them made out of aluminum I believe (so that they wouldn't crack).
Old May 8th, 2012, 11:21 AM
cthoekenga's Avatar
cthoekenga
1997 BRG D90
Thanks Josh. I will check it out. I do have to say, you have an unbelievable amount of Rover knowledge!! Thanks again for the quick reply!
Old May 8th, 2012, 11:32 AM
I don't see it in his old threads though. Maybe it wasn't him? I remember a metal one being made (could have sworn out of aluminum) just can't recall for certain if it was him - seems like something he provided though. Give his shop a call and he'll remember better than I do.
Old May 8th, 2012, 02:15 PM
mneil
Mark Neil
ROW D90 SW (TD5)
aka the "hockey stick." George at Rovers Down South usually has them, if the aluminium one that Josh mentions doesn't pan out.
-Mark
Old May 8th, 2012, 02:21 PM
Yep. I remembered it's called the lower dash trim finisher or something. The part comes up as AWR5987
never found the aluminum thing I thought I saw. Must have been a dream or something. I know I wasn't thinking of the aluminum dash cowel, but that's all that kept coming up.
Old May 8th, 2012, 02:42 PM
KKilo23's Avatar
KKilo23
Kenny
Rovers North has... http://www.roversnorth.com/p-9288-fi...fender-90.aspx
Old May 9th, 2012, 06:46 AM
rovertrader's Avatar
rovertrader
Dale
Josh- I believe the piece you are thinking of is the main support for the cluster, etc that Stephen had made from aluminum in lieu of the plastic OEM piece.
little plastic thin piece that is glued down to cover the light near the heat switch d90guyinla Wanted 10 February 5th, 2013 05:01 PM
Heater / Vent plastic decal Cayoweso Defender Technical Discussions 3 March 6th, 2006 12:38 PM
Soft top plastic windows paulb Defender Technical Discussions 8 March 22nd, 2005 08:58 PM
Plastic Rear Cargo Tray? OCD90 Wanted 8 April 17th, 2004 04:45 PM
» Defender Registry
The Mule
crash05
Shell
toddw
Add your Defender
