Parts to mount A/C to V8 - Defender Source
Old August 30th, 2015, 04:26 PM
ghfaris
Graham
1984 D-110
Gents,
I am getting ready to add A/C to my 4.6 V8. One of the things I am having trouble figuring out is mounting the A/C compressor to the engine. Seems simple, but I am struggling. Maybe you have some advice or parts lying around you are willing to sell?
It does not currently have a mount on the engine to hold the compressor. Where the compressor should go is where the alternator currently sits. I have attached a picture. What I would like is to find a bracket(s) that will mount the compressor where it should be and move the alternator to allow this.
The engine is a 4.6 V8 that was made by RPI engineering.
Hopefully, there is someone with experience with mounting accessories to these engines can help me out.
Graham
Old August 30th, 2015, 04:38 PM
Originally Posted by ghfaris View Post
Gents, I am getting ready to add A/C to my 4.6 V8. One of the things I am having trouble figuring out is mounting the A/C compressor to the engine. Seems simple, but I am struggling. Maybe you have some advice or parts lying around you are willing to sell? It does not currently have a mount on the engine to hold the compressor. Where the compressor should go is where the alternator currently sits. I have attached a picture. What I would like is to find a bracket(s) that will mount the compressor where it should be and move the alternator to allow this. The engine is a 4.6 V8 that was made by RPI engineering. Hopefully, there is someone with experience with mounting accessories to these engines can help me out. Graham
Wouldn't the easiest option be to go to a pick and pull and take the bracketed off a disco?
Old August 30th, 2015, 05:37 PM
carlosz's Avatar
carlosz
Carlos
I have the bracket set for the serpentine belt set on the early serpentine engines 93 to 99, 3.9. 4.2, 4.0 disco1 and classic range.
I don't know how much I paid for that. Let me know if that is what you are looking for and we can work a deal...I'm on a deal making mood.
the truck ran like a "raped ape"
A fussy warm weather creature...
Old August 30th, 2015, 05:55 PM
ghfaris
Graham
1984 D-110
Its currently V-belt. Im not opposed to switching to serpentine, but that might be another can of worms. If its doable I need advice on that too.
Old August 30th, 2015, 06:17 PM
you will need a rrc or defender set up. The compressor bracket bolts to the front of the right side head, ie where your alternator lives now. You need a good bit more that the compressor bracket and tensioner based on your picture.
Old August 30th, 2015, 06:22 PM
ghfaris
Graham
1984 D-110
Any suggestions where to go for the whole setup?
Old August 30th, 2015, 06:35 PM
Rob Bass 240-899-8173
Old August 30th, 2015, 06:57 PM
ghfaris
Graham
1984 D-110
Old August 30th, 2015, 07:49 PM
carlosz's Avatar
carlosz
Carlos
nevermind, the serpentine conversion begins with the newer timing cover, water pump, p/s pump, idler, tensioner, harmonic balancer, bolts and all the pulleys...
easier way to achieve such is by going to a junks yard, preferably a pick a part, locating a mid 94 to late 95 disco 1 or 94 95 classic and pull the timing cover with distributor and all the front of engine parts.
with your current set up, you need to find a 87 to 93 range and take anything related to belts ...
Old August 31st, 2015, 02:25 PM
TigerDan's Avatar
TigerDan
Dan
1991 RRC
On a RRC, the power steering pump mounts fairly low on the left side, it looks form the pic like yous sits up higher. There's a bracket that bolts to the head behind the P/S pump which mounts the alternator just above the pump and uses an odd belt and pulley arrangement with the alt. belt being driven by the crank pulley but going around on both sides of the P/S pump pulley. The A/C compressor mounts to it's own bracket along with the belt tensioner on the front of the right cylinder head.
I've parted a few RRCs and have everything you need to do this swap. Alternatively, if you should decide to go Serpentine belt, it's quite different and you will indeed (as mentioned above) have to change the timing cover and all accessories. And a few fittings as well. The A/C compressor mounts completely different from the V-belt compressor and the fittings on the lines are different as well, and new lines may well have to be fabricated by a hose shop depending on your evaporator and condenser connections.
1991 RRC 4.2, R380, LT230, TrueTrac, Detroit, sliders, 33s, blahblahblah....
1994 RRC LWB
1994 RRC SWB
1995 D90 project
1961 SII
Old August 31st, 2015, 10:07 PM
ghfaris
Graham
1984 D-110
Definitely staying V-Belt for now.
ac, mount, part, parts, v8
Parts, parts and parts dogbite For Sale - Parts 37 January 21st, 2015 10:19 PM
Parts, Parts and More Parts Lemonhead For Sale - Parts 13 November 27th, 2012 10:18 PM
Rear light mount bracket four bolt mount riser thing-a-ma-bob evilfij Wanted 14 June 5th, 2009 06:11 PM
WTB Wing Mount Pick Ax Mount NashvilleRover Wanted 1 September 13th, 2008 10:29 PM
WIng top shovel mount parts needed Cyborg Wanted 0 March 8th, 2006 11:12 AM
