Park Brake Brakets - Defender Source
Old November 18th, 2010, 02:51 PM
CDeWan
Clay DeWan
5.3L beastie
Park Brake Brakets
O.k. here goes -
I have #58 of 94 D-90s (early model) so what I need is:
parking brake bracket (and nylon washers and pins)
that fits to the LT230 T-case to actuate the parking bake.
My current brake drum has a lever arm that comes out of the drum and when pulled on via the braket set up and cable to hand brake engages the parking brake.
Please let me know if you have the set up.
Danke shon,
Herr Clay
There is another set up whereas the cable goes into the park brake housing - NOT looking for that type.
Old November 19th, 2010, 08:10 PM
CDeWan
Clay DeWan
5.3L beastie
E Brake
No one has these? O.K. who is hording these brackets. I know you are out there its the Clatrix. Kinda like the Matrix but not really. Take the blue pill!
Must have brackets or no park brake.
Old December 3rd, 2010, 07:58 PM
CDeWan
Clay DeWan
5.3L beastie
bump
Old December 3rd, 2010, 10:59 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Wow Clay - mine is #48, with all your '94 questions of late, I didn't realize they were that close. Are you trying to reassemble the e-brake, or am I misunderstanding? I'm having my whole e-brake rebuilt right now because the PO didn't understand how it worked, and ditched the important parts. Again, not sure of your needs, but I ended up needing 2 key parts: AEU2734 and STC244. Both are cost prohibitive OEM here in the states. Ended up getting aftermarket from LRDirect.com for a fraction of the OEM cost.
Edit:
I just re-read your post, I doubt that helps, but you never know.
brake
Brake Line ? RoverChic Defender Technical Discussions 18 March 5th, 2007 05:45 PM
Clogged brake lines? Heath Defender Technical Discussions 11 February 24th, 2006 08:39 AM
Emergency Brake Issues Ragland Defender Technical Discussions 10 April 7th, 2005 07:09 PM
