Oxygen Sensor Connector - Defender Source
Old September 18th, 2015, 12:57 PM
mattm's Avatar
mattm
Matthias Moran
1963 109
From any 3.5/3.9/4.2 vehicle.
I only need the connector with a few inches (say 3 minimum) of wire.
If you were going to throw away your old sensors, please cut off a connector and send it to me instead. You'll be saving me a trip to the junk yard.
Will happily pay shipping plus say $20 ?
(I'm in San Francisco, CA)
- Mat
Old September 18th, 2015, 01:47 PM
Or cut both ends and fit up a new WeatherPack 3 way.
Old September 19th, 2015, 01:31 PM
TigerDan's Avatar
TigerDan
Dan
1991 RRC
I can help you out with that, I've got some dead sensors. I'm in Lake county but away for the weekend, pm me your address and I'll get it on its way the first part of the week.
1991 RRC 4.2, R380, LT230, TrueTrac, Detroit, sliders, 33s, blahblahblah....
1994 RRC LWB
1994 RRC SWB
1995 D90 project
1961 SII
Old September 21st, 2015, 09:07 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
TigerDan: Since we're talking connectors, you wouldn't happen to have the 5-pin main connector for the main harness that feeds power to the ECU, would you? I'm looking for the male mating part. It's either black or white in color and the pins are arranged in 2 rows.
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old September 21st, 2015, 01:33 PM
TigerDan's Avatar
TigerDan
Dan
1991 RRC
I'll take a look at a couple of scrap RRC wiring harnesses I have and see if they have the connector you're looking for. A pic might help though.
1994 RRC LWB
1994 RRC SWB
1995 D90 project
1961 SII
Old September 21st, 2015, 02:13 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Great, thanks. Here is a picture of the plug (female end). Looking for the male end with as long a lead as you can manage (pigtails).
Thank you - Samer
2003 Discovery II
Old September 21st, 2015, 02:18 PM
TigerDan's Avatar
TigerDan
Dan
1991 RRC
No, don't have any of those to spare...I use them to make Rovergauge/USB connector cables.
1994 RRC LWB
1994 RRC SWB
1995 D90 project
1961 SII
Old September 21st, 2015, 02:28 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
I must be confused then, as I assumed that this plug was the main feed to the EFI. It has 5 pins and they seem to be heavy gauge wires.
The plug you are referring to is Diagnostic Plug/Data Link Connector, and that's only a 3-pin plug. No? If not, what does the EFI Power Cable look like?
Thank you - Samer
2003 Discovery II
Old September 21st, 2015, 02:51 PM
TigerDan's Avatar
TigerDan
Dan
1991 RRC
Those connectors are used in various places around the vehicle. The data connection for the ECU uses that style of connector, but only uses 3 of the 5 pins.
I really don't know what connector you're looking for...I'm not even sure that there is specifically an EFI power cable connector. I just dug out a couple of my harnesses for a better look, including my '94 D90 engine harness, and all that there is in the vicinity of the ECU connector are the relays for the fuel pump and ECU and their connectors, the diagnostic connector and in the case of the D90 harness, two yellow relays on their connectors. If you are looking for a connector that mates to one you pictured above, as I already stated, I don't have any available right now.
1994 RRC LWB
1994 RRC SWB
1995 D90 project
1961 SII
Old September 21st, 2015, 03:00 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Fair enough. The harness you described sounds a lot like the one on my engine, and so does the diagnostics connector, so I'll leave that alone, especially if I decide to use Rover Gauge.
So, how does the EFI get power from the ignition switch and battery, etc then?
Thank you - Samer
2003 Discovery II
Old September 21st, 2015, 03:07 PM
TigerDan's Avatar
TigerDan
Dan
1991 RRC
I'd have to look at a wiring diagram to see the exact path it takes, but it should be from a 12V source to the relay which is of course switched by the ignition, and from there to the ECU connector. Of the two metal-clad relays, the one with the blue connector is for the fuel pump and the black connector is the ECU relay.
1994 RRC LWB
1994 RRC SWB
1995 D90 project
1961 SII
Old September 22nd, 2015, 10:11 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Take a look at this pdf. It shows which pins the power & ignition are. And from the other thread, they both come in from that white connector.
http://p38arover.com/rover/p38a/Engi...UX_Systems.pdf
sensor
Beck/ Arnley oxygen sensor Mpigapicha Defender Technical Discussions 4 June 28th, 2010 08:13 AM
Oxygen Sensor Bank Placement Cory Defender Technical Discussions 1 December 18th, 2009 09:58 AM
Oxygen Sensor TND90 Wanted 0 April 17th, 2008 03:04 PM
Oxygen Sensor Testing Antonios Defender Technical Discussions 6 April 1st, 2006 10:24 PM
OXYGEN SENSOR Question? ... Vendor ? norros Defender Technical Discussions 4 June 7th, 2004 07:14 PM
