Overdrive for Defender - Defender Source
Old March 15th, 2017, 12:56 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Anyone have one that they are thinking of parting with? Such as a GKN or Global Roamer?
Old March 15th, 2017, 09:41 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Anyone have experience with one? Would like to ear about the pros & cons...
Old March 15th, 2017, 10:03 AM
4RF RDS
Kevin
2000 110 XS CSW
I have one sitting in the box awaiting install. Its a Global Roamerdrive from Ray Wood out west in Vancouver. Was going to install a Disco T-case (1:21) as I did in my 300Tdi years ago but decided to go for the OD in my 110 instead. I shall post a response or a new thread once I get it in. Still a tad too cold in the garage to gidderdun.
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Old March 15th, 2017, 10:37 AM
DiscoDavis
C Davis
1990 110, 1995 Disco
This one has been from Ushuaia to Alaska, when I saw it in CH it had returned from a quick jaunt through the boonies in Romania. Fitted to a Td5 130 SW, fully loaded. Never saw quite how it did on anything but flat plains but the whole vehicle was quick and cruised very well on the highway and normal roads.
Cons I could imagine it is adding complexity to the drivetrain, but I know both the owner and his mechanic and they had nothing but good things to say, and it was driven new from 1999 all over the world and back.
Old March 16th, 2017, 12:32 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
I have a roamer drive in my d130 . 300tdi variable vane turbo, ported head ,full intercooler ...R380 1.4 box
I honestly can say it not worth the effort . It will reduce cabin noise and revs but the motor does not have enough legs to sustain cruising speed on any kind of incline or sweeping road youll find yourself shifting to 4th alot . 4th od is almost exactly the same gear as 5th and 5th od is too dead to keep it in the power egts climb fast with it laboring in 5th od .
Sent from my SM-G920P using Tapatalk
No Mall crawler here
Old March 16th, 2017, 03:15 AM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
The Roamerdrive will give you a 28% reduction in RPM when engaged. Well worth adding if you do much highway driving. I see it as one of the best mods I have done so far.
Old March 16th, 2017, 09:23 AM
BRAB
Brandon
200TDI in a RHD 1986 D90
Had a romverdrive roverdrive on my 200tdi with an VNT turbo, same as chris V here the truck had no balls to pull it.
Old March 16th, 2017, 11:32 AM
DiscoDavis
C Davis
Judging by responses here, so far only good results with Td5 models. Kind of agree I can't imagine my 200tdi having enough oomph to make the OD worth it.
Old March 16th, 2017, 12:30 PM
4RF RDS
Kevin
2000 110 XS CSW
Send Ray an email or call him at Global, you may well be correct thta the 28% decrease is too much for the venerable 200 Tdi. My 300 Tdi with the 15% of the Disco I t-case was great. My current 110 is a Td5 and has bags of pull. We'll see once I get the OD in it.
Good luck.
Old March 16th, 2017, 12:32 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
I would agree that the little extra power with the td5 will make it usable .
Old March 16th, 2017, 07:53 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
I always thought they would do better sales if the reduction was 15% instead of 28%. I considered one when all I had was a 1.6 TC. Then I found a 1.4.
d-90 200tdi vs. 109 w/ 2.5 & overdrive isleofbones Defender Technical Discussions 4 December 28th, 2012 06:26 AM
Roasted overdrive red64chevelle Series Technical Discussions 17 December 6th, 2011 09:09 PM
Overdrive in D110 with 33 inch tires? Santiago Defender Technical Discussions 19 September 29th, 2011 02:33 PM
Overdrive for 110 with 2.8 TGV Santiago Defender Technical Discussions 96 March 6th, 2011 09:36 PM
overdrive lobster Defender Technical Discussions 11 May 9th, 2005 08:30 AM
