old lt95 diff lock switch - Defender Source
Old October 9th, 2012, 12:41 AM
Trey C
Trey Crowther
1983 V8 110 County
My difflock switch is toast. Anyone have one of these vaccum switches ?
Old October 9th, 2012, 08:36 AM
Trey C
Trey Crowther
1983 V8 110 County
Worse. My knob is glued in the off position with epoxy. Dad switched the lines and difflock seems to work, just need a switch. That would be great Jeff
Old October 9th, 2012, 10:51 AM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
Trey - I thought I had a spare in a box in the garage but I can not seem to find it.
You should put your request out to a better - more LT95 friendly - forum. Search the Stage One BBS (http://www.stage1v8.org.uk/phpBB3/) or try to troll the UK second hand parts dealers. I am sure your Dad can make room in one of them fancy containers for a little old switch.
Firemanshort
1980 Stage One 109
Sterling, VA
Old October 9th, 2012, 11:57 AM
grnrvrs's Avatar
grnrvrs
Paul
88
Trey, check out tntlr. they have been in the process of closing down for a while, but still list FRC5656 for reasonable money. Or go mechanical.
Edit: Or something like post 14: http://www.aulro.com/afvb/isuzu-land...version-2.html
1970 SIIA 88, Sold
Old October 9th, 2012, 01:13 PM
Trey C
Trey Crowther
1983 V8 110 County
my actuator seems fine. Dad was able to get it to lock and unlock by switching the vaccum around, just need the shifter/switch. Dad can't have anything smaller than a pallet delivered to the stuffing warehouse where his containers load. I'll try TLR, dad knows Bill.
Old October 10th, 2012, 12:14 PM
grnrvrs's Avatar
grnrvrs
Paul
88
T, I had another Q in to Bill at TNTLR and asked about the switch. No dice.
1970 SIIA 88, Sold
Old October 13th, 2012, 05:38 PM
Trey C
Trey Crowther
1983 V8 110 County
fixed it- no longer need one. BTW-new they are 180gbp
Old October 14th, 2012, 09:51 AM
What did you do to fix it?
-Jeff
Jeff,
I managed to get the knob/shifter to move in and out. I used a marine product I had on hand called Bond Breaker that is meant to break the bond of 3M 5200, a marine adhesive/caulk. I worked some of that in and with persistence broke the bond of what ever the brits had it glued with. I followed up with some CRC Knock'er Loose and with some more gentle persistence its working freely.
The bigger question in my mind is why did they disable the difflock in the first place.
95, switch
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
Defender 200tdi...oil pressure sensor and diff lock switch sonoronos Defender Technical Discussions 4 July 28th, 2011 05:10 PM
Diff Lock Light Wiring for 83-89 -- Modern T Case Switch Answered SafariHP Defender Technical Discussions 0 September 3rd, 2009 12:36 PM
Diff Lock Remains Engaged but Light is Off - Whats Wrong? R. Kurk Defender Technical Discussions 14 April 5th, 2009 12:01 AM
4 Wheel / Diff Lock hamiamham Defender Technical Discussions 4 August 7th, 2007 08:50 PM
