NoVa area... Headlight Switch - Defender Source
Old September 11th, 2013, 11:43 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Gents, against a time crunch again. Seems as though my headlight switch finally gave up the ghost and again, I need to get the 90 operational by Friday. Any NoVa folks have a headlight switch handy? Either part number AMR6104 or PRC3430. If not, I may try to solder it temporarily. Thanks
Old September 12th, 2013, 12:07 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Yeah, Ive had the IPF one for months now...in storage.
Old September 12th, 2013, 09:13 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Rugbier is slight away from NOVA but was selling one (not sure part #).
You can still overnight it.
If your goal is just "running", then just use wires to act as the switch. That's how I drove down to MAR from here a few years ago (and back).
BTW, I am interested in your burnt out switch! I'd like to use one on my toylander project.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old September 12th, 2013, 10:15 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
I don't know what it looks like in the switch, but I assume jumping it is pretty self-explanatory? I'll save you the old switch when I get a new one in next week.
Old September 12th, 2013, 10:32 AM
Very self explanatory.
You could easily refurbish the switch by cleaning the contacts and soldering on new pads.
Old September 12th, 2013, 11:16 AM
Depends how bad the switch is. I've seen them melt/deform.
-Jeff
Good point Jeff...I guess I am being idealistic.
Old September 12th, 2013, 11:33 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Ok, found some threads where my symptoms matched with a faulty turn signal stalk. So no trail fix for that one I assume? Anyone got a turn signal stalk local?
Old September 12th, 2013, 12:01 PM
I have a spare one...
Also, try moving it slowly. When mine went, I could turn it on by slowly moving the switch forward and then leaving it in between the contacts. I finally replaced it. But, ran it like that for years.
Old September 12th, 2013, 12:12 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Thanks Scott, Ill give it a try. Unfortunately, Im in DC so trying to reach out to the NoVa fellas.
Old September 12th, 2013, 12:28 PM
Not good news for Loic, but the easiest is to cut the harness on the switch side so you have the plug still in the harness for the new one, and then short those wires together to turn the lights one. If you use those twist on wire nuts it's easy to do.
I actually have one of those pigtails here but it's probably not worth the effort trying to get it from me.
Originally Posted by pendy
I'm here for the D's
Old September 12th, 2013, 12:48 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Im fairly sure its the turn signal switch now. You dont have one laying around do you? I read your wiring ordeal you had a while back regarding this. Wonder if there is a workaround.
Old September 12th, 2013, 12:50 PM
No, sorry. But if it's just affecting the headlights you can still bypass the switch I think. Wouldn't want to hack up your switch wiring to figure it out but you can jumper at the connectors to prove/disprove it will work.
Old September 12th, 2013, 12:54 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Ill give it a shot. Im still wondering if I may have caused this from the LED install. Thanks
Old September 12th, 2013, 02:47 PM
MonLand
Loic Fabro
-Jeff
Yes, mine melted/deformed. With enough will, it can be rebuilt (with a Bakelite plate/whatever substrate is used in a printed circuit board and some rivets, not rocket science in there!)
MonLand
1995 D90 NAS
1996 Discovery NAS
Old September 12th, 2013, 02:57 PM
MonLand
Loic Fabro
The plug would probably have to go anyway since I would not have the one from the harness! no... No harm!
Side note, if you are considering this: pulling the switch was easy from what I remember and opening it was also decently easy. The contact in my case had melted through the board and that was easy to see.
If that helps troubleshooting: in my case high beams were working (only when using the momentary position of the switch???), I want to say that the parking lights were working but the low beam were definitely not. It was fun driving in pitch dark night.... Got t practice the "use incoming light to see side of the road" technic I was taught many years ago.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old September 12th, 2013, 03:11 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I think I still have an old turn signal switch that I believe is good but I do know that the horn button is missing...not sure if this helps and I can confirm that the switch didn't get tossed tonight if needed
Old September 12th, 2013, 08:55 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Resolved...not really but renting a car until it's fixed. And as usual, I'm going to throw parts at it until it works... Thanks all.
Old September 12th, 2013, 09:12 PM
Damn man...you need to just start driving this thing, and only fix what actually breaks .
Old September 12th, 2013, 09:42 PM
The Dro
Dro
1988 Ninety
Déjà vu
Old September 12th, 2013, 09:48 PM
Originally Posted by The Dro View Post
Déjà vu
Droja vu
ht, nova, switch
Using headlight leveling switch (AMR5875) to activate ARB compress and lockers NomaD110 Defender Technical Discussions 7 September 6th, 2011 04:01 PM
PDF headlight switch area wiring diagram please huck1974 Defender Technical Discussions 3 December 2nd, 2007 10:22 PM
Headlight Switch Issue, any ideas? januconn92 Defender Technical Discussions 1 July 24th, 2005 11:53 AM
94-95 headlight switch.. can be broken TDI Guy Wanted 4 May 17th, 2004 06:28 AM
headlight switch sub jorge Defender Technical Discussions 1 January 24th, 2004 09:10 PM
