non working A/C compressor? - Defender Source
Old December 23rd, 2007, 11:02 PM
jim_harriger
Jim Harriger
1997 D90 S/W
Question non working A/C compressor?
we just removed the A/C out of our '97 S/W, and would like to sell it to someone who wants and needs it, but to make it an attractive deal, i need to sell the compressor with it. problem is, the compressor pulley needs to be present on the engine for the poly-belt to follow the correct path. i'm therefore looking for an A/C compressor with a pulley that spins well, but the compressor doesn't need to work. anyone?
jim harriger
duvall, wa
blackdog@blackdogandmagpie.net
Old December 24th, 2007, 12:27 AM
madcowdungbeetle
Carter
Just source another shorter 7-rib polybelt. They are available from summit racing in various lengths, or for an even larger selection you can run a 6 rib belt with no problems just as well.
Also, late model Jeeps use a 7-rib belt as well if I recall.
One last edit, but I think you should be able to clock the belt tensioner to work in a non-AC configuration if necessary. I did this with my Discovery.
Old December 24th, 2007, 12:56 AM
Since all the 97's come with an ac compressor, I would keep your compressor and just sell the kit. Anyone with a 97 will already have the compressor, and anyone with a 94/95 is going to need a different pulley at the very least, so I would let them source their own compressor.
Old December 24th, 2007, 01:26 AM
jim_harriger
Jim Harriger
1997 D90 S/W
thanks, all. this does give me some things to look at. i appreciate it!
jim
Old December 26th, 2007, 07:19 PM
GYM's Avatar
GYM
Gary
97 SW
Couldn't you just use the serp belt for a UK non-AC 4.0? Then you'd have no need for a compressor at all....
I seem to recall someone at one time posting up the Land Rover PN for the non-AC serp belt, but said you had to buy it from the UK....
compressor
a/c compressor jblieb Wanted 2 October 6th, 2005 02:02 PM
removing clutch place from a/c compressor Campbell Defender Technical Discussions 2 May 1st, 2004 02:58 PM
A/C compressor, hoses, and condenser for 95 D-90 727chop Wanted 0 April 8th, 2004 11:21 AM
A/C compressor is whinning Campbell Defender Technical Discussions 7 April 1st, 2004 03:59 PM
can I remove a/c compressor belt? Campbell Defender Technical Discussions 20 November 1st, 2003 10:07 AM
