Need intake/carb setup for 3.9 - Defender Source
Old September 14th, 2011, 03:21 PM
rovertrader's Avatar
rovertrader
Dale
Building a simple noncomputer truck and need the intake/carb, new or used, thanks. PM is best
Old September 14th, 2011, 03:50 PM
Edelbrock makes the intake and you can plop a Performer 1403 500 cfm carb on there (with the needle spring kit) and you'll have your induction.
Old September 14th, 2011, 04:15 PM
wantone
Rick Thompson
94 ST #1222
me as well. i found the edelbrock items, but stopped at the fuel pump part, i understand a low pressure pump is needed, but have not researched it completely to make it work with the current tank/pump/return set up.
Old September 14th, 2011, 06:25 PM
Easy. Take out the tank pump and install a low pressure tank pump from a mustang. About 50 clams. You're just replacing the electric pump, not the entire in-tank unit. You will not need a return, so you can cap it off.
I'll try to find you a link to a pump that'll work.
Alternate Plan B (what I did on my boat) is to keep the OE fuel pump and install a return type fuel pressure regulator. This will drop the high pressure feed down to a reasonable 7-9 psi and return the overflow to the tank using the existing plumbing.
Old September 15th, 2011, 06:23 PM
rovertrader
Dale
great, thanks- and $25 rebate to boot...
Have you used this set up and I assume liked it? Any negatives?
Old September 16th, 2011, 11:09 AM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
I have the edelbrock set up on my 3.5 in my Stage One.
It provides very nice power, is as simple as a stone, and is reliable. My fuel economy has not really suffered. I jetted it down quite a bit from stock and still am not completely happy about the ultra-fine tune. (I need to borrow someones exhuast gas meter to really know what I am doing.) The carb is a little big for the 3.5 - but should do nicely for the 3.9 and even better for the flame-thowing 4.6 motors.
I do think that this carb is very unhappy about getting at weird angles. When I off road and get stuck on hard angles (up or either left or right) then the motor runs like crapola and it takes three feet to clutch, brake, and goose the gas to keep it runnning. I did install the off road spring kit, as well.
I got the manual choke carb - I thought it would be nice to re-attach the factory choke cable. I have never used the electric choke model and only assume it works well.
If you off road lightly and spend a lot of time on tarmac and want simple reliability - I fully support this carb conversion.
Firemanshort
1980 Stage One 109
Sterling, VA
Old September 17th, 2011, 12:43 PM
wantone
Rick Thompson
94 ST #1222
David, which carb are u running & what fuel pump? Anything else needed besides carb, manifold ,pump? Thanks!
3-Link Suspension Setup questions chrisvonc Defender Technical Discussions 20 July 18th, 2006 10:37 PM
'97 Defender radio & changer setup? Defender50th Defender Technical Discussions 6 September 27th, 2005 11:22 PM
Rockware setup: which Ranchos? artm Defender Technical Discussions 2 October 28th, 2004 07:29 PM
GBR 4.75 3rds and Extreme front axle setup for sale billnsandi For Sale - Parts 2 January 4th, 2004 11:10 PM
Wheel/Tire setup for snow? PT94D90 Defender Technical Discussions 11 October 16th, 2003 03:42 PM
