Need halfshaft! - Defender Source
Old December 8th, 2015, 09:38 AM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Need halfshaft!
I am having a hard time finding an in-stock halfshaft for my 86 110. Right hand side, 24 splines at the flange, 10 at the diff. Will pay extra handling for fast shipping. Ok with used in good condition!
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old December 8th, 2015, 10:30 AM
AEU2520 10/23 short shaft. I'm sure there must be a lot of people with ones lying around after upgrading. I just gave my last spare away last month.
Old December 8th, 2015, 10:45 AM
ontheway's Avatar
ontheway
Dave
Ok, I suck. Miscounted. Won't say how even though I literally got off the phone with Trevor and recounted a second time! I'll attribute this to me watching 2/3 kids this morning.
So yeah - anyone have short 10/23 halfshaft lying around?
Old December 8th, 2015, 10:50 AM
You did say 24 spline at the flange, which is correct.
Old December 8th, 2015, 10:58 AM
ontheway's Avatar
ontheway
Dave
yeah you nailed it... I went out to the garage and counted the driving member splines instead of removing the half shaft and counting that... dumb.
Old December 8th, 2015, 02:29 PM
ontheway's Avatar
ontheway
Dave
Bump
Old December 8th, 2015, 02:46 PM
rangerover's Avatar
rangerover
Patrick
1990 Range Rover
I'll double check once I'm home, but, I believe that I have an extra stored away
1990 Range Rover
1995 Range Rover LWB - daily driver
Old December 8th, 2015, 06:24 PM
rangerover's Avatar
rangerover
Patrick
1990 Range Rover
sorry, mine's 10/32 , not 10/24
1990 Range Rover
Old December 8th, 2015, 08:55 PM
I have a 10/32 set as well, so no help. Why don't you just upgrade fronts now to 24 spline? defender/disco 3rd member, shafts and cv will be much easier to source. if you have to do the right front regardless, not alot of extra work to do left front and be done.
Mark Kellgren
KM4BOR
Old December 8th, 2015, 09:04 PM
ontheway's Avatar
ontheway
Dave
What's involved for the swap? I am all for parts availability
Old December 8th, 2015, 09:13 PM
UserName's Avatar
UserName
Andy
Janey
I have one here in NH andcan bring it to work tomorrow morning. If you still need it I can overnight it to you tomorrow. This is the AEU2520 although it is still connected to a CV: AEU2522.
Let me know.
This Ad Space For Sale!
Its the only space left on this site not already running a slow loading pop-up commercial.
Comes with free cookie downloader and user tracking virus. (superior to the ones Vertical Scope downloaded onto your computer when you logged in)
Old December 8th, 2015, 09:15 PM
throw in a D1/D2 3rd member. straight swap for your 10 spline. (caveat-on mine, I used a D2 3rd. I had to replace the studs (cheap-RN) on the axle casing because the D2 3rd member housing flange is thicker than older casings like my original)
once you have the 24 spline diff, then you are good to go for late model 24 spline axle shafts and CV's. same spec as NAS D90.
Mark Kellgren
KM4BOR
Old December 8th, 2015, 09:36 PM
Umm, because the 24/32 setup is much weaker and big downgrade.... Much weaker at the CV joint and worse bearing setup.
To upgrade you would change to aftermarket 24/23 shafts and a proper aftermarket diff. But that is money!
Old December 11th, 2015, 07:39 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
I got one if you still need it? Let me know
Old March 10th, 2016, 01:52 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Does anybody know what the difference is between the older- and newer-style front half-shafts?
According to an ancient D-90 FAQ post by Bill Davis, the older style shafts measure 1.185" in diameter, whereas the newer shafts measure 1.030" in diameter. Presumably, he's referring to the diameter of the non-splined portion but I'm not certain.
KAM and Ashcroft claim that their front half-shafts are compatible with the AEU2520/AEU2521 factory half-shafts and I'm sure this is true, but I'm curious about the profile difference.
I suppose I could make sure that my iPhone has a full charge and call Bill but I'm hoping that someone here can answer first.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Broken halfshaft maybe? Can only drive in Diff Lock. Gish Defender Technical Discussions 6 September 5th, 2015 05:54 PM
NY: LH front halfshaft assembly Lyman For Sale - Parts 9 March 25th, 2007 07:33 AM
