Need Fuel Filter Housing for 300TDI - Defender Source
Old March 20th, 2018, 11:07 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Well my bleed screw was stripped, maybe by me, maybe for always, would explain some of the starting issues I have been having.
At any rate, I changed the fuel filter and went to bleed the housing and found that as I tightened the bolt it just kept spinning...
In a bit of a desperate need for a housing (or suitable replacement, I see the standyne ones mentioned around) currently my daily driver is a lump of parts without this system being sealed. LR Direct said part was unavailable (from them anyway) so I presume that will be the case with most UK suppliers. Was hoping to get lucky on the board.
Any suggestions?
Filter Holder
Old March 20th, 2018, 11:14 AM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
Craddocks, maybe.
Or call SHP
------ Follow up post added March 20th, 2018 12:14 PM ------
Also see WJN500180
KGH - “Stinky LR diesel” Defender Snob
Old March 20th, 2018, 11:27 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
SHP is just so expensive on this item its hardly worth it
Old March 20th, 2018, 11:30 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Reliable Industries . Com
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old March 20th, 2018, 11:36 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I see that, but I'd need fittings and BS to go along with it.
Right now the fastest swap would be someone who, like yourself, pulled their old housing and went with a different setup and has their take off lying in the garage...
the 300TDI/200TDI is the same housing
Old March 20th, 2018, 11:40 AM
roverman2010
1985 LR 90 200Tdi
Why not re-tap the hole?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old March 20th, 2018, 11:45 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I mean I could, but as Bartleby said, I'd prefer not to
Old March 20th, 2018, 12:08 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
Hi JT,
Pretty sure I have an extra one. I will check and get back with you.
Hey, did you still have an extra 300tdi AC compressor and setup?
Let me know 615 681 8441
Cheers,
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi 5 speed SoftDash (My Son's)
"Be the person your dog thinks you are"
Old March 20th, 2018, 12:23 PM
Any Bosch diesel shop will have one. It is a common Bosch filter head used in a lot of things.
Old March 20th, 2018, 12:30 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I have the bosch part number and have tried to locate it without a lot of luck.
Anyone know if there is a REF number for this so I can call around?
Old March 20th, 2018, 12:43 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I found this but its discontinued
Old March 20th, 2018, 12:54 PM
I don't know other than when I've been to the local Bosch shop, they knew what it was and had them on the shelves. I never looked into it beyond that. It could be that they are NLA. The world moves on.
I run Stanadyne filters on my trucks. Much better filtration which extends injector life. you just need a couple of compression fittings and plugs, which you can get at a hardware store.
Old March 20th, 2018, 01:10 PM
What did you look for?
The part number is WJN500180 or NTC1518.
https://www.ebay.com/itm/Land-Rover-...MAAOSwrklVAGux
Old March 20th, 2018, 01:13 PM
roverman2010
1985 LR 90 200Tdi
Hows about my new Stanadyne filter head. filter of your choice, comes with two 1/4"npt 3/8 barb fittings just need two 1/4" npt plugs (homedepot) some 3/8" fuel hose and a couple of jubilee clips for your old head and I'll pay the shipping. Can have it out tomorrow.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old March 20th, 2018, 01:18 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I see them there, was just hoping to get it domestically so I could have it by the end of the week.
Ebay stuff definitely takes 5-7 business days from the UK
Old March 20th, 2018, 01:38 PM
If only you'd done a little more shopping at the barn you'd be golden.
Old March 20th, 2018, 01:39 PM
rovertrader's Avatar
rovertrader
Dale
PM sent
NPT90's Avatar
NPT90
JT
D90 óriginalé
If I made you look for any more bits you'd have gotten nothing else done all weekend
As it is you have me looking at autosparks relay holders as of Sunday... curse you and your electrical install!
Old March 20th, 2018, 01:48 PM
Naplm00
M
I also have to vote for the stanadyne it's worth the $10 and fittings you have to get at Home Depot
Old March 20th, 2018, 01:54 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
For the best stainlesss steel fittings look at Swagelok compression fottings, we used them on our robots at Lockheed
300tdi, fuel, tdi
D90 Fuel pump stays on jackaaaps Defender Technical Discussions 0 January 23rd, 2014 08:46 PM
300 Tdi Egt Q?????? Buckon37s Defender Technical Discussions 37 July 11th, 2012 10:26 AM
D-90 air filter housing cap needed (horn) arbik Wanted 4 November 30th, 2010 11:45 AM
95 won't start, possible fuel priming issue? jcasteel Defender Technical Discussions 1 March 15th, 2005 08:45 AM
How to get d--- fuel pump housing back in NAS tank? Chris Cox Defender Technical Discussions 3 October 29th, 2004 08:58 AM
