Need exhaust down pipe for 19j - Defender Source
Old July 25th, 2014, 09:22 AM
LRover's Avatar
LRover
J. Michael McCaig
Looking for a good used exhaust down-pipe (NTC4426 or ESR159) for a turbo diesel (19j) for my Series conversion project. This is the pipe that connects to the engine and I may need the second pipe that it connects to also if you have it. PM me or email to lr88 at aol dot com
Thanks!
Old July 25th, 2014, 09:54 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I can cut one off of that 1984 110 if that will help.
RDavisinVA
Old July 25th, 2014, 10:43 AM
LRover's Avatar
LRover
J. Michael McCaig
Hey Robert - yes that would help as long as the upper end is good. I hope to adapt it to the rest of the Series exhaust at the bottom end.
Old July 25th, 2014, 10:47 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Series exhaust will be restrictive, but will work.
RDavisinVA
Old July 25th, 2014, 11:32 AM
LRover's Avatar
LRover
J. Michael McCaig
Yeah, I hope to find someone who can bend pipe and make a copy in a size a half inch larger diameter. Steve Walker in the UK makes an exhaust kit for this conversion but the shipping was way more than the cost of the kit
Old July 25th, 2014, 01:35 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You'll want 2" pipe minimum.
I have a shop make bolt together flanges, buy mandrel straight, 45deg, and 90deg pipe sections, buy a flex exhaust coupling, cut the ends off a Mercedes 300D muffler and weld one up when the vehicle is on the lift.
It is easy.
The only draw back is the process is time consuming.
The couplings are a triangle made of 1/4" steel with a 2.25" hole in the center. Each corner is rounded and there is a 3/8" X 16 tapped hole in each "corner" on one piece and a hole just large enough for a bolt on the other.
One side is welded to 1 pipe and the mating pipe and the flange bolts together.
Then you can make the whole system in pieces that bolt together, so you can remove sections to pull the transmission and so on.
RDavisinVA
exhaust
200tdi down pipe bossman429 For Sale - Parts 11 September 18th, 2012 05:51 PM
300 tdi turbo and down pipe dogbite For Sale - Parts 1 March 29th, 2011 06:42 PM
19j exhaust and intake millerhlyf Wanted 1 March 23rd, 2011 10:06 PM
Coming Soon, SS Y-pipe + Off Road Pipe Trailhead 4x4 The Vendors Loft 39 September 30th, 2009 09:02 PM
Is a NAS 110 Y-pipe the same as a 1995 D90 NAS Y-pipe evilfij Defender Technical Discussions 5 February 12th, 2009 06:10 PM
