need dual pulley for Lucas alternator - Defender Source
Old October 9th, 2014, 01:53 PM
cdb
Clark Bowen
I was removing the generator from my 1965 109" and dropped it on the pulley - shattering it and the generator case. Because I have a capstan winch the gen/alt needs a dual v-belt pulley.
I have a Lucas alternator that I can install, but I don't have a dual pulley for it.
Anyone have one they are willing to sell or know where I can find one?
The inside diameter of the pulley is 2.375" and outside is 3.25". The bore is 15mm or .59".
2011 RR HSE -
2001 GMC 2500 4wd
Old October 9th, 2014, 02:02 PM
I think the 15 mm is a tough find. If you switch to the the 65 amp alternator that is standard on Defenders, it has a 17 mm hub with the same mounts as the 45 Amp one and there are lots of options for pulleys.
This is the one I did for my Lightweight: http://store.alternatorparts.com/par...ord-1g-2g.aspx
Old October 9th, 2014, 02:08 PM
Apparently the double groove pulley is part number 574870, which looks pricey. I wonder if I still have the old one around??
Old October 9th, 2014, 06:12 PM
cdb
Clark Bowen
John.........
Is this the number for the 15mm or 17mm hole diameter? It doesn't say on Paddocks site.
I'm assuming the keyway is the same as the original generator pulley..
2011 RR HSE -
2001 GMC 2500 4wd
Old October 9th, 2014, 06:21 PM
I'm pretty sure that will be the 15mm one.
alternator, pulley
New genuine Lucas Distributor - Lucas 35D8 pabrit For Sale - Parts 0 June 1st, 2012 04:13 PM
Anyone have an alternator pulley and a harmonic balancer they can measure? Turbofan Defender Technical Discussions 0 October 21st, 2011 10:35 PM
Alternator pulley JFD Defender Technical Discussions 0 September 21st, 2009 07:49 AM
Adding a 2nd alternator pulley Jackd Defender Technical Discussions 5 September 11th, 2009 10:13 AM
dual flexalite dual electric fan setup (2500cfm) crown14 For Sale - Parts 5 May 5th, 2009 10:33 PM
