Need a steering box - Defender Source
Old September 25th, 2017, 09:19 PM
Backstay
John Hilton
1994 D90
Need a steering box
Anyone got a good used (dry) steering box for a 90 NAS ? My 2 year old rebuilt one is leaking like a sieve.
Old September 25th, 2017, 09:22 PM
Grab a used D1 or RRC one.
Send what you have to Meridian in ? San Diego?
Old September 25th, 2017, 09:52 PM
rayfi's Avatar
rayfi
Derek Moeller
110
It works! For awhile?
Old September 25th, 2017, 09:55 PM
Backstay
John Hilton
1994 D90
Thanks, maybe I'll try that till I find a good used one.
------ Follow up post added September 25th, 2017 06:56 PM ------
Thanks, been looking.....
Old September 25th, 2017, 11:08 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
First, make sure it is properly tightened/adjusted. If the adjustment screw is loose, it will leak from it as it will if there is too much slop in it.
Secondly, do NOT use the Lucas power steering fluid stop leak. It is made for use in systems using power steering fluid which is why it works like crap. Use Blue Devil Transmission Sealer (https://www.amazon.com/BlueDevil-Tra...ct_top?ie=UTF8 ) We use Transmission fluid and the seals are for transmission fluid. It works. There are some threads on here attesting to it...
Old September 25th, 2017, 11:20 PM
Backstay
John Hilton
1994 D90
Great info. Thanks.
Old September 26th, 2017, 09:19 AM
Paul Grant
Paul Grant
i have a few used boxes that are in good shape. I would refrain from saying they don't leak or are bone dry (anyone selling a used box making such a claim should be viewed with a jaundiced eye), they weep. Hell, back in the '90's when I had a brand new RRC the box was weeping a little over three years down the pike. I will say that the boxes I have won't need constant attention and do work the way they should.
Paul Grant
203-770-1699
Old September 26th, 2017, 09:32 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
This! likely the only fluid I don't lose is power steering after adding the blue devil product.
pretty amazing results
Old September 26th, 2017, 10:34 AM
I ran quarts of this stuff through Trey's 1983 110 before I got the whim to try the Blue Devil stuff in it. The only advantage to the Lucas product is it takes longer to leak out because it's thick. My rationale for trying the Blue Devil trans sealer was it needs a box now, what can it hurt ? That was what 4 years ago now and still haven't had to add fluid.
Glad its working for the rest of you. 10 yrs ago this forum used to be full of posts about leaking steering boxes. Blue Devil to the rescue.
Old September 26th, 2017, 10:37 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Guess you can go get your money back though.
Old September 26th, 2017, 10:58 AM
rayfi's Avatar
rayfi
Derek Moeller
110
Sounds like I need to give the Blue Devil a try.
But seriously the Lucas oil did stop the leak in my steering box probably as Douglas implied because it is so thick it can't run out but the down side to that is that the pump is working very hard until the oil is warmed up.
Old September 26th, 2017, 12:09 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I tried lucas on 3 trucks and it sucked on everyone. I love Lucas products (except the electronics) so I wanted it to work better. Doug--was it really 10 years ago that I saw your original post? Wholly hell. Well I used the Blue Devil back then in my Disco (it worked) and my RRC (it worked). And when my rebuilt box starts to leak, I will use it in that too! I did have a horrible leak in the D90's box last year and it turned out it was the adjustment screw... hence why I say check that first. I tightened that up and it stopped leaking (I have Blue Devil on my shelf though, just in case!). Thanks for the original suggestion, Uncle Doug!
Old September 26th, 2017, 04:18 PM
Backstay
John Hilton
1994 D90
I'll try the Blue Devil and report back!
Old September 26th, 2017, 04:21 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Another +1 for Blue Devil. Stopped my leak.
Old September 26th, 2017, 04:50 PM
Factoid's Avatar
Factoid
Mark
Three criminals seeking revenge
Just to be clear, are you saying to use tranny fluid in your PS box and then Blue Devil if/when it leaks or will the Blue Devil work if you are using PS fluid?
1976 Series III 109 "Montoya" ("You killed my father, prepare to die")
1988 Defender 90 LHD "Vizzini" (speed demon from Sicily)
1987 Defender 90 MOD LHD "fezzik" (giant rock thrower)
1975 Porsche 911 hot rod
1964 Porsche (Beck) 904
Old September 26th, 2017, 04:57 PM
phoenix37's Avatar
phoenix37
john
I used the blue devil tranny stop leak and it worked.. Did not try the steering stop leak and yes there was still a bit of regular power steering fluid in the reservoir.
Old September 26th, 2017, 05:01 PM
You are never supposed to use PS fluid. It is designed for ATF.
Old September 26th, 2017, 05:11 PM
Factoid's Avatar
Factoid
Mark
Thanks, John, I know that for a pure LR set up. My question is probably not appropriate for this thread. I had jumped to my specific set up which uses a GM pump with a LR box.
Old September 26th, 2017, 05:28 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
That's a good point, factoid--- is the fluid specific for the pump or the steering box??
Rent my
Old September 26th, 2017, 05:30 PM
phoenix37's Avatar
phoenix37
john
same deal..it was in my LS 110.. So LR box and GM pump.
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
More Steering Box Questions kzack Defender Technical Discussions 6 May 5th, 2011 12:51 PM
Where to buy reman steering gear box? Chris Cox Defender Technical Discussions 4 February 25th, 2011 12:02 PM
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
