Need a place to put the kids.... - Defender Source
Old February 17th, 2007, 10:09 AM
BKnotts
Brandon Knotts
1994 D-90
I am looking for a forward facing bench seat for my 94 d-90. Thanks.
Brandon
Old February 24th, 2007, 06:42 PM
jvelador's Avatar
jvelador
Javier Velador
'95 D90 / '66 IIA
I have a bit of advice. I have the stock D90 seat, but I was worried because there is no neck/head support in case of a collision. So I bought a pair of gray Range Rover headrests from Will Tillery and had a local shop weld brackets to mount them. The look is factory, even though the shades of gray a little different.
The place that did it is UrbanOffroad and their contact info is at http://www.urbanoffroad.us
Javier
ID:	8333   Click image for larger version
Old February 25th, 2007, 10:42 AM
mountainviewrover's Avatar
mountainviewrover
MARK LECLAIR
95 Range Rover Classic
so, you have no seat(s) in the back right now? if you have jumps i will swap with you for my bench.
ac
Cheapest place to buy Tuffy console, Mantec snorkel Chris Cox Defender Technical Discussions 7 March 14th, 2005 09:21 PM
Where did you put your ECU jcasteel Defender Technical Discussions 6 January 12th, 2005 11:31 AM
arb switches - where to put scoloco Defender Technical Discussions 8 January 10th, 2005 09:25 PM
Best place to get a 1997 workshop manual? P1CR Defender Technical Discussions 2 December 20th, 2003 07:37 PM
Cheapest place to buy a tuffy center console JRowe Defender Technical Discussions 3 October 6th, 2003 10:42 PM
