NAS ST Roll Cage Diagonal ("Tie Bar") ALR5544 or ALR7823 - Defender Source
Old June 13th, 2015, 12:46 AM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
The piece that comes down diagonal from the upper rear of the B pillar hoop to the tub. The foam is split on the left side one (driver's) so its rusted and coming apart. Anyone have one? I prefer the 94 style, but the 95/97 style would be okay, but in that case I'd probably need the right side (ALR7822) as well so it matches since mine's a 94.
------ Follow up post added June 12th, 2015 09:53 PM ------
If I were to cut the foam off and then repair the metal there's probably no way to put the foam back on huh? Is there any product that will permanently stick it together?
Old June 13th, 2015, 01:35 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
I don't see why a spray adhesive wouldn't work? You will have a nasty seam on the inside but I think it's possible.
Old June 13th, 2015, 01:37 AM
Chip's Avatar
Chip
Andrew
Okay, I guess I could try it.
Old June 13th, 2015, 01:43 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Take a box cutter to the inside seam with a straight edge and make a straight cut all the way down to the metal. Once all the way through the rubber will peel away, imagine a pool noodle. I have done this several times when shortening the contrails for installing the cages on five door 110's. When reinstalling spray contact adhesive on both the bar and the inside rubber. It should work. Let me know how it goes...
Old June 13th, 2015, 03:01 AM
Chip's Avatar
Chip
Andrew
Okay, awesome. Thanks!
cage, nas
D90 Roll Bar Diagonal Supports for NAS B Hoop Method PHX For Sale - Parts 0 September 22nd, 2014 07:18 PM
NAS Roll A bar roll cage and front under wing supports defenderholty For Sale - Parts 6 August 9th, 2014 05:49 PM
Used "B" pillar diagonal bar covers/wraps -For Sale HeloBubba For Sale - Parts 8 March 23rd, 2012 10:58 AM
ST cage diagonal minorthreat Wanted 1 June 4th, 2010 03:35 PM
ST Cage diagonal. minorthreat Wanted 0 December 4th, 2009 06:36 PM
