NAS SD Roof Rack. - Defender Source
Old February 5th, 2007, 06:35 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
NAS SD Roof Rack.
I need one. Preferably on the West Coast. Cosmetically, I don`t care what it looks like so long as it`s decently solid. $1500-ish?
PM me or email me, mela.n @ neu .edu
Old February 12th, 2007, 08:42 AM
oldscratchggf
nate
95 d90
bump
Old February 12th, 2007, 02:41 PM
jvelador's Avatar
jvelador
Javier Velador
'95 D90 / '66 IIA
Nathan,
Sent you an email.
Javier
Old February 12th, 2007, 03:28 PM
oldscratchggf
nate
95 d90
hmmm, didn`t see it. I`d really appreciate it if you try again though.
either should work
mela.n @ neu.edu
or
oldscratchggf @ hotmail.com
Old February 13th, 2007, 03:21 PM
jvelador's Avatar
jvelador
Javier Velador
'95 D90 / '66 IIA
I took pics of UrbanOffroad.us' basket prior to cleanup and powder-coating for anyone who is interested. It is side-by-side with my original SD basket for comaprison. You'll notice the ends are not crimped, making what I believe is a stronger basket. This particular one was made for a 110 and the mount points were perfectly aligned with factory mount points. Give them a call if you are interested in one for yourself. Also, they now have a rear ladder that also mounts to factory mount points, so the holes you'll drill will be the same as if you were mounting an OEM ladder. As soon as I can get more pics, I'll post them on d-90.com
The prices are $1800 and includes crossbars. You can then order the mount brackets, plates and buy stainless steel M8 asnd M10 bolts. I ordered my mounts and mounting plates from http://www.roverconnection.com
http://www.roverpalooza.com/images/DefenderRack1.JPG
http://www.roverpalooza.com/images/DefenderRack2.JPG
http://www.roverpalooza.com/images/DefenderRack3.JPG
http://www.roverpalooza.com/images/DefenderRack4.JPG
Their contact information is at http://www.urbanoffroad.us
Cheers!
Javier
Old February 13th, 2007, 03:56 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Do they also sell the ladders too?
Neil
Old February 13th, 2007, 04:16 PM
jvelador's Avatar
jvelador
Javier Velador
'95 D90 / '66 IIA
Neil,
If you mean a D90 rear ladder, Yes. Pics of the first prototype should be available soon. I'll probably let him use my D90 to verify factory mount points. When we do, I'll post pics for your viewing pleasure
You'll see my contributions to the design (for those that request the optional extras). In summary, he can add limb risers, Hi-Lift mounts, jerry can holders, additional light tabs, you name it, he can add it.
He's ready to take orders, just drop a deposit of 1/2 and he'll get started.
Javier
Old February 13th, 2007, 05:15 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
i just sent him an email. it will fit a ST and SW right? i have a POE top, and like to take it off in the summer and go ST.
also, it looks like its built very well!
Old February 13th, 2007, 06:20 PM
Defender13's Avatar
Defender13
Mike Lynch
1994 Defender 90 #1017
is that 1800 for the 90 or 110?
Mike Lynch
Old February 13th, 2007, 06:41 PM
jvelador's Avatar
jvelador
Javier Velador
'95 D90 / '66 IIA
Mike,
That's $1800 for the D90 basket, ladder, crossbars and roll cage mounts. I think that's a helluva price. I paid a little more than that, and that was scrounging used parts from boards and new from roverconnection.com.
Daniel,
He's going to have two sets of crossbars, one for ST and another for SW. The only difference is the SW roll cage is 1" taller, hence the need for a 1" spacer on STs.
He's a good guy, very honest. If you have problems, tell him I'll sequester his puppy until his customer is happy
Javier
Old February 13th, 2007, 06:58 PM
ini88's Avatar
ini88
Daniel Marcello
Originally Posted by jvelador
Mike,
Daniel,
Javier
so if i got the ST set with the added 1 inch given to the crossbars then it would still work when i did the SW in the winter, i would just have an extra inch higher when the SW rollcage bars were put on? doesn't sound so bad! i hope my Tax money comes in quick.
Old February 13th, 2007, 07:30 PM
jvelador's Avatar
jvelador
Javier Velador
'95 D90 / '66 IIA
Daniel.
I'd suggest you get the ST crossbars and have a 1" spacer made out of aluminium. That way, it'll be correct height either way.
Javier
Old February 13th, 2007, 10:29 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
I called and talked to him too.
Here is what I found out.
He is making several for a production run, but has none available now.
From the time you order, it will take approx. 3 weeks.
The price is just under $1800.00 for a complete roof rack kit including rear ladder. It includes all mounting hardware and all bolts are stainless. It is identicle to the SD rack except the welds are boxed in instead of crimped, which makes it stronger.
Basket is available for $1,198.00 alone.
They will be made of 1/16th inch tubular steel and will mount just like the safety devices rack.
The entire kit weighs less than 100 lbs, and is $160.00 for shipping to a business location.
They will come with tabs for mounting lights in the rear of the basket, and for additional charges he will add things like a hi-lift carrier, spare tire carrier, limb riser tabs, etc...
He also said that he could shorten the height of the basket to whatever size I wanted for an additional $100.
I think I will order one soon.
Old February 14th, 2007, 01:14 AM
ini88's Avatar
ini88
Daniel Marcello
the only difference i see in the SD and his is that the SD's edges bow out a bit when they round up to the top. very minor detail which doesn't bother me at all. the box welds i like!
ac, nas, rack, roof, roof rack
ST roof rack mounting question Matt Taylor Defender Technical Discussions 8 March 9th, 2006 03:45 PM
Custom Rovers North D90 Roof Rack Barnett Childress For Sale - Parts 0 October 9th, 2005 07:29 AM
NAS Style Roof Rack for D-90 Joe P Wanted 14 October 4th, 2005 12:56 PM
ISO: ANY PARTS for NAS safety devices roof rack NASD90 Wanted 3 February 28th, 2005 01:22 PM
WANTED: NAS Safari Roof Rack m.michaels Wanted 3 November 10th, 2004 11:34 AM
