NAS D90 fuel tank - Defender Source
Old May 12th, 2013, 06:29 PM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
NAS D90 fuel tank
After removing my rusted fuel cradle and ordering a replacement I've discovered that my fuel tank has been damaged. It not only has some cracks in it but the exhaust has also partially melted one side.
Rovers North doesn't have any in stock and I haven't been able to find another one online. Anyone have a spare that's in good shape that they are willing to part with or know of where I can pick one up?
Thanks!
Old May 12th, 2013, 06:31 PM
They're long gone no longer available. cgalpin from here had some good posts on using an epoxy of some sort (from what I recall) if you search around.
------ Follow up post added May 12th, 2013 06:32 PM ------
And I believe member found90 had his for sale a few years ago for a few hundred bucks, but I'm not sure it's in better condition than yours is.
Old May 12th, 2013, 06:44 PM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
Thanks for always being quick to help, Josh! I'll search for that thread.
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
I asked found90 about the tank a while after he had posted it, and he had already tossed it unfortunately
Old May 12th, 2013, 07:12 PM
Isn't there a place in TX making metal pricey replacements?
Old May 12th, 2013, 07:14 PM
Nothing for NAS as far as I've seen.
Old May 12th, 2013, 09:37 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Stephen at Safari HP has/had one...they are pricey. Fortunately you do have options.
Old May 13th, 2013, 12:27 AM
m016324
benjamin tanner
94 D-90
shoot me an email. I am pulling my stock tank for a custom one and can sell it if you are interested. bjt6179@aol.com
-ben
Old May 13th, 2013, 12:31 AM
bjf's Avatar
bjf
barry f
94 ST #395
-ben
What are you replacing it with and more importantly why?
Old May 13th, 2013, 01:56 AM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
Barry, the tank had cracks in it (I'll try to take some photos when I get back to the shop) and was leaking fuel. It was also warped/melted on the side nearest the exhaust. Epoxy has been suggested to patch the cracks. The melted part hasn't resulted a loss in structural integrity but makes me wonder if there was supposed to be a better heat shield in place. I saw the below part on roverparts but I haven't seen anything like that on my truck.
http://www.roverparts.com/Parts/ESR2756G.cfm
Old May 13th, 2013, 02:19 AM
bjf's Avatar
bjf
barry f
94 ST #395
Not you. I meant the other guy replacing his.
Old May 13th, 2013, 05:43 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
Bill at Kensington Motor cars makes an full aluminum replacement tank. If I remember correctly, it's 3 gallons bigger than the factory one and has a built in slid plate. Saw one in Moab and it's really beautiful. It's a direct bolt in replacement. You need to call as they don't post them on the site. I think it was $1400. plus shipping which is very reasonable considering they get $700. for a used piece of plastic with bits typically broken off.
Here is the link http://www.kmcnv.com/
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old May 13th, 2013, 06:59 PM
Thank you Scott that's the guy. Think its closer to $2k now....
Old May 23rd, 2013, 08:15 PM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
Still on the lookout for a replacement fuel tank replacement. If anyone has any leads, they would be much appreciated. Thanks again.
Old May 29th, 2013, 12:56 PM
maleger
Marc-Andre Leger
Did you find anything ?
I was thinking of changing my fuel tank when I do some work in the rear section and must drop the tank anyway.
Old May 29th, 2013, 01:10 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Why change it? Take it to a shop to have it blasted, pressure tested and red koted! Cost around $150 bucks and it will be as good as new!
Old May 29th, 2013, 01:12 PM
It is plastic on a NAS D90.
Old May 29th, 2013, 01:20 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
cgalpin had good luck plastic welding his tank. I don't have the link handy but if you PM him he can give it to you.
Old May 29th, 2013, 02:03 PM
maleger
Marc-Andre Leger
There is nothing wrong with my tank, except it's 20 years old... I was thinking of changing it while I was there.
Worst case, I'll at least get all the slime out of it and steam clean it inside and out..
d90, fuel, nas
1997 NAS D90 soft top Beluga Black 86K hlamar For Sale - Vehicles 30 July 24th, 2013 11:11 AM
NAS 110 fuel tank lines/evap canister Q Overlander Defender Technical Discussions 16 January 27th, 2013 04:53 PM
Rover Accessories D90 transfer fuel tank cdb Defender Technical Discussions 20 June 21st, 2011 05:01 PM
Factory Aux. Fuel Tank? Willh Misc. Chit-Chat 20 May 10th, 2010 09:39 PM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
