NAS 90 ST Cage Cantrails - Defender Source
Old October 11th, 2016, 06:06 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Looking for a pair of good condition padded Cantrails - the longitudinal bars connecting the B and C pillars.
Old October 11th, 2016, 07:34 PM
jperakis
James Perakis
94 ST
get in line
I posted a similar request months ago and got zero responses.
Even called some of the known shops and got no traction.
When is someone going to make a viable alternative to the OEM rubberized cage?
remember two things...
Old October 11th, 2016, 07:38 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
I know there are some out there. They do come up for sale every so often, but timing is everything. No issues with the metal on my set, just the rubber.
Old October 11th, 2016, 08:15 PM
Exmoor sells a padding kit which covers the destroyed rubber.
Old October 11th, 2016, 08:18 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
I've seen that. The rubber is coming off in chunks. Thought about coming up with some type of high density foam in the same shape as stock to go under the exmoor padding, but would prefer the real thing.
Old October 11th, 2016, 08:32 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
If you find someone selling the whole kit and caboodle, I say we buy it and split it up. I need a better set of diagonals and I know there are people after B and C hoops.
"Barry is correct!"
Old October 12th, 2016, 12:16 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
I suppose I would consider that as an option.
Old October 12th, 2016, 12:21 AM
D90Overkill
David Frank
1995 ST #2615
Sounds like a plan. I'm good for the diagonals and maybe even the C. Just keep me in the loop.
"Barry is correct!"
Old October 12th, 2016, 07:23 AM
And I need your diagonals when you find new ones. Actually just need one fully padded 1995-97 one. Can't remember which side now though.
Old October 12th, 2016, 12:40 PM
D90Overkill
David Frank
1995 ST #2615
Ok. Mine are great except for the small section of the inner foot plate that the POS PO cut out to install the jump seats. Unbelievable! ;-(
"Barry is correct!"
90, cage, nas
Rear Cage C hoop and cantrails lordhelemt For Sale - Parts 4 April 16th, 2015 10:26 AM
New rear cage hoop and cantrails rayfi For Sale - Parts 2 September 26th, 2012 01:04 PM
Cantrails mightymg Wanted 0 August 17th, 2009 10:52 AM
WTB C-pillar and cantrails for 94ST Dilks Wanted 0 June 11th, 2007 02:01 AM
Replacing Cantrails, need advice! Harrisonml Defender Technical Discussions 0 October 7th, 2006 07:50 PM
» Defender Registry
Yoda
Colo
Carlos3082
Add your Defender
