NAS 1994 D90 underbody rollcage pieces - Defender Source
Old June 11th, 2015, 12:28 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
As the title says. Pops is looking to replace a piece or two and is all too common with rovers once you start digging you find other items that need replacing. So who has what, etc...
Old June 11th, 2015, 12:33 PM
All of them? SafariHP has/had at least a few of the pieces.
Old June 11th, 2015, 01:03 PM
airbornrover
William Skidmore
SIII 109 SW
True Josh, but never hurts to see who has what packed away gathering dust and their spouse asking them when they are going to unload their "stuff"
Old June 11th, 2015, 01:09 PM
ATX_D110's Avatar
ATX_D110
Victor
1985 RHD D110 (SOLD)
Not exterior but I have the interior support piece that fits behind the seats and/or could replace the rear bulkhead of an ROW 90 - Sorry, not sure of the proper name.
Old June 11th, 2015, 02:16 PM
airbornrover
William Skidmore
SIII 109 SW
Appreciate that. Mainly looking for the underbody parts. Appreciate the heads up though.
Old June 11th, 2015, 03:03 PM
rovertrader's Avatar
rovertrader
Dale
So are you wanting A hoop supports, C hoop supports, and the under body bulkhead replacement bar?
Old June 11th, 2015, 06:55 PM
airbornrover
William Skidmore
SIII 109 SW
Primary piece as of right now is alr5557 part #16. The tube with a bracket on each end and runs from one side to the other.
Name:	Messages Image(1908597823).png
Old June 11th, 2015, 07:47 PM
bjf's Avatar
bjf
barry f
94 ST #395
Isn't 16 inside the truck?
Old June 11th, 2015, 07:57 PM
airbornrover
William Skidmore
SIII 109 SW
Nope that is #11.
Old June 11th, 2015, 10:58 PM
This is really convoluted. The exploded diagram is for an early-94 Soft Top cage before LR eliminated 16. So 16 is inside the truck.
How about you just take a picture of the part you want?
Old June 11th, 2015, 11:02 PM
bjf's Avatar
bjf
barry f
94 ST #395
Originally Posted by JimC View Post
This is really convoluted. The exploded diagram is for an early-94 Soft Top cage before LR eliminated 16. So 16 is inside the truck. How about you just take a picture of the part you want?
Thought so
Old June 12th, 2015, 07:22 AM
He's talking about ALR5557 which is the crosstube underbody that goes below the W bar across the tub behind the driver and passenger.
Old June 12th, 2015, 09:23 AM
budzny
Real4X4
NAS 97 ST/NAS 93 110/62
Birthday Committee Team
Pm me, I have everything you need. Even NAS Hard top internal cage!
Sal
Old June 12th, 2015, 11:52 AM
There's a couple favors of that as well. One with continuous piece with integrated flanges, and one split version which requires u-bolts to connect it to separate brackets. Whatever he gets he'll want to make sure he's got all the parts. I'm not sure the OEM one will come out without cutting it in the middle. I don't profess to know all the versions out there.
Old June 12th, 2015, 12:09 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
I would be in the market for a pair of part #16 that is runs long inside the tub for the early 94' ST. PM me if you have a pair.
Old June 12th, 2015, 12:41 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Confusing because he posted two exploded diagrams with different numbers. Number 16 on one of them is the underbody crossbar that runs under the truck in the same place as the bulkhead bar. I've seen this in 1-piece and 2-piece versions. This piece often has corrosion on the 'ears' where it joins the body.
Number 16 on the other diagram are the interior bars that run along the inside of the tub that were only on early '94s.
Old June 12th, 2015, 08:33 PM
airbornrover
William Skidmore
SIII 109 SW
Sorry for the confusion. Thought I was being clear with my description. When you are communicating in the medium you think you are being clear but then people read completely different, lol. As Josh said I was talking about part ALR5557 which as far as I can tell is one piece. I have some photos you can look at. Will post pics in a few
ID:	122821   Click image for larger version
ID:	122823   Click image for larger version
ID:	122825   Click image for larger version
ID:	122827   Click image for larger version
Old June 12th, 2015, 09:14 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Originals are 1 pc some of the replacements are sleeved in the middle so you don't have to remove the body to install. I have seen both... fYI I have all that for you if you haven't found it yet.
Old June 12th, 2015, 11:14 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Will - pull the pieces off - bring them over and we can just zap some new metal onto them - then up to V&S to galvy so it doesn't do it again for a long time.
Old June 13th, 2015, 12:36 AM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
That one looks just like mine. lol
1994, 90, body, cage, d90, nas
Defender 110 Differential Guards & Underbody Plates: Which Ones? samer0214 Defender Technical Discussions 21 October 3rd, 2014 10:25 AM
1994 D90 Fiberglass top and NAS Rollcage abraded For Sale - Parts 4 January 9th, 2008 10:33 AM
1994 NAS D90 Safari rollcage Shane@EVS For Sale - Parts 7 May 13th, 2006 05:23 PM
rollcage rollcage rollcage javablack Wanted 0 October 9th, 2005 05:06 PM
Underbody Potection Dfndr90 Defender Technical Discussions 6 August 18th, 2004 04:04 PM
