NAS 1994 D90 underbody rollcage pieces - Page 2 - Defender Source
Old June 13th, 2015, 12:59 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
I have brand new brackets and make them if you guys need to replace the ends. Just let me know...
Old June 13th, 2015, 01:00 AM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
Okay cool. How much for the ends and brackets?
Old June 13th, 2015, 09:56 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
That would be cool, but dont think the old man has the time for that, sorry. Galv run maybe.
Originally Posted by don View Post
Will - pull the pieces off - bring them over and we can just zap some new metal onto them - then up to V&S to galvy so it doesn't do it again for a long time.
------ Follow up post added June 13th, 2015 09:58 AM ------
How much for the one piece unit?
Originals are 1 pc some of the replacements are sleeved in the middle so you don't have to remove the body to install. I have seen both... fYI I have all that for you if you haven't found it yet.
Old June 13th, 2015, 10:01 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
I have one on the shelf new for $475 from SD, and a good used one for $300 both original. And the mounts to connect to the frame are $100 a set, which are the ones I make.
Old June 13th, 2015, 10:04 AM
I am also 99 percent sure you can't get the one piece version out or a new one in without cutting it.
SD will probably sell you a new one.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 13th, 2015, 10:08 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Originally Posted by Ren Ching View Post
I am also 99 percent sure you can't get the one piece version out or a new one in without cutting it. SD will probably sell you a new one.
you are 100% correct, you have to pull the tub to install them. They also go under the fuel lines which is a biotch as well.
Old June 13th, 2015, 10:12 AM
ATX_D110's Avatar
ATX_D110
Victor
1985 RHD D110 (SOLD)
X2 on the tub/body removal - Just had to do it on a 90 to install.
Old June 13th, 2015, 12:22 PM
Chip's Avatar
Chip
Andrew
Rover's North sells the 2-piece one from Safety Devices for $269.95. It's quite a long wait for it though. They have to make them I guess. I'm interested in just the ends and also the brackets, but I'll talk to my friend Curt about it first. He's pretty good making stuff like that from scratch.
1994, 90, body, cage, d90, nas
Defender 110 Differential Guards & Underbody Plates: Which Ones? samer0214 Defender Technical Discussions 21 October 3rd, 2014 10:25 AM
1994 D90 Fiberglass top and NAS Rollcage abraded For Sale - Parts 4 January 9th, 2008 10:33 AM
1994 NAS D90 Safari rollcage Shane@EVS For Sale - Parts 7 May 13th, 2006 05:23 PM
rollcage rollcage rollcage javablack Wanted 0 October 9th, 2005 05:06 PM
Underbody Potection Dfndr90 Defender Technical Discussions 6 August 18th, 2004 04:04 PM
