Name this locked lug - Defender Source
Old May 8th, 2011, 10:28 PM
Does anyone know what kind of Lug Lock this is, and does anyone have the key? Or is it one of those kinds that you'd need a serial number in order to be able to provide the right key?
The lug has a tin cap that looks just like a regular alloy capped lug nut, but it is removable, then it has these outer teeth that I'm assuming the key would link up with? You basically have to tap them to know which one is the locking one.
Let me know if you'd be willing to sell it.
Thanks!
Old May 8th, 2011, 10:29 PM
bjf's Avatar
bjf
barry f
94 ST #395
I used to have the fake cap wheel locks but it didn't look anything like that. Mine looked like all the others people have. This is weird for sure!
Old May 8th, 2011, 10:38 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
I have seen those before somewhere... just trying to remember!
Old May 8th, 2011, 10:40 PM
Yeah, trying to help out a fellow Hoboken-ite. He has a slow-ish air leak but the lug key didn't come with the truck.
Old May 9th, 2011, 02:14 AM
specops1526's Avatar
specops1526
Beluga '97 90
I doubt you'll find a key for it as all the lug keys are unique. I've had several sets of these and they have all been unique to each set:
http://imageshack.us/f/18/img19591.jpg/
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old May 9th, 2011, 02:26 AM
bjf's Avatar
bjf
barry f
94 ST #395
That looks more like the standard locking lug (similar to what I had without the cap). The one Horsey posted looks different.
Old May 9th, 2011, 09:32 AM
Roving Beetle
Doug
That's an odd one. Chances are you will need to pound a large torx bit or tripple-square in there and get them off that way.
Sorry.
Series coiler monster in building process, in gather parts mode.
Currently driving an ex-southern 1993 SWB RRC with too much "kit". Massive conversion and interior swap in process.
Lots, lots and lots more have come and gone....
Old May 9th, 2011, 10:07 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Why would anybody sell a truck without the key for that. I bet it is in one of the seat pockets or somewhere in the truck. If it came from a dealer I would be pissed. Maybe you could track down the previous owner.....
Old May 9th, 2011, 10:17 AM
Brian, what you attached is what I have on my truck, too...this is totally different though.
Yeah, right? I forgot to look in his seat boxes, but I'm assuming he has looked in there, as he knew an amp wasn't in there (we were comparing trucks). When he saw my lug lock set/box, he was surprsed what it looked like, so I'm assuming he has not seen it around before.
Old May 9th, 2011, 10:18 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
We get a lot of new purchase 90s with wheel locks and no "key". Major PITA, but you'd be surprised how many people have no idea where their wheel lock keys are.
Excellent suggestion to search the entire car though. Hopefully you will be lucky. Over the years I have collected a lot of the "keys", but I don't have anything that looks like that.
Email:
Old May 9th, 2011, 10:22 AM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Are you sure that is a wheel lock?
Old May 9th, 2011, 10:27 AM
tjfslaughter
thomas
Burbon
http://britpart.com/AccessoryCategor...ategoryRef=215
I think I found the page you need. Good luck.
Old May 9th, 2011, 10:52 AM
Each wheel had one.
Man, I was really hoping that'd be it, but I was looking around on there, and none appear to be what he has, but I appreciate the effort!
Old May 9th, 2011, 12:31 PM
tjfslaughter
thomas
Burbon
http://www.sears.com/shc/s/p_10153_12605_00947392000P
Old May 9th, 2011, 12:43 PM
specops1526
Beluga '97 90
I know what I posted was different but it was just to illustrate that these things are uniquely keyed, so I assume finding a key for it would be nearly impossible unless he had a serial number for them. I think he'll have to check out one of those vids above or talk to a locksmith.
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old May 9th, 2011, 02:05 PM
If you have enough clearance beat an old long reach socket over the end and remove like wheel thieves do!
Old May 9th, 2011, 02:11 PM
It's hard to tell exactly what it looks like, but you might just be able to run an east-out extractor down the center and back it out. I did one once where I had to get a large easy-out and cut the end off to get it to go far enough into the locking nut to get bite.
Old May 9th, 2011, 03:39 PM
Naplm00
Matthew
Can you just drill it out? then replace the stud when the wheel is off? Also they make some MASSIVE reverse threaded stud removers..or just just a hammered in torx.
Old February 3rd, 2015, 01:28 PM
mpodgorski's Avatar
mpodgorski
martin
'94 D90 ST Arles
I might be in the same boat as the above mention member. No key in removing these wheel locks.
Old February 3rd, 2015, 01:32 PM
Find a tight fitting socket, pound it on with a hammer and twist it off with a ratchet. That is what Husky brand sockets are good for.
or
Weld a nut to the top and use a good socket and remove it. You don't need to destroy the stud or the wheel removing it.
Stupid Question.....about lug nuts excanuk Defender Technical Discussions 31 July 22nd, 2008 06:38 PM
Lug wrench - do they really shrink?? paulb Defender Technical Discussions 4 June 26th, 2005 01:42 PM
Disco II Lug Nuts javelinadave For Sale - Parts 0 January 21st, 2005 11:55 PM
more lug nuts erik d For Sale - Parts 0 January 1st, 2005 12:27 PM
Lug Nuts!!! Get loose today !!!! Vadim Defender Technical Discussions 10 October 26th, 2004 03:58 AM
