MOD roll bar or similar - Defender Source
Old February 7th, 2012, 08:58 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Almost done compiling the parts to convert the truck cab to a soft top for the summer. At this point all I need is a solution for the upper seat belt mounts. Ideally the solution would include some sort of roll bar. It seems like the easiest solution would be to source an ex-MOD soft top roll bar. Anyone have one or something similar?
Old February 7th, 2012, 09:10 PM
BOBCAT110's Avatar
BOBCAT110
Ken Jagolta
94 d-90
Exmoor makes a front seat belt bar for just such an occasion. I ordered one from Stephen in Dec. but have not received it yet...part # is EXT500-1.
Old February 8th, 2012, 09:34 AM
Naplm00
Matthew
A note on the MOD roll bar/seatbealt bar.
The one i have is designed to replace the hood stick in the furthest forward location on the bed. It also required special cappings to allow for the roll bar to slide through into the bracket below. Or you can cut your existing capping larger. With the roll bar in place you cannot put a truck cab hard top in place without cutting off or bending the seat belt mounts out of the way.
My solution will be to cut my existing capping and cut off the seat belt mounts from the roll bar, (im using lap belts anyway)
Im putting a bar from a 90 into a 110, so there are some other slight differences as well
Old February 8th, 2012, 09:55 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Ken, thanks for mentioning that exmoor product -- while I know the MOD bar isn't great, I'd love to try and find something that offers a modicum of protection. I may have to look again at that safety devices option. . .
Matthew, great points there, thanks. My intent was to run the bar and soft top for 3 seasons and drop the pickup cab back on for the winter. Which obviosuly will never happen . . .
Old February 8th, 2012, 11:07 AM
Naplm00
Matthew
this is exactly what im doing, I use an air powered 3/8 ratchet to swap tops, takes about 30 min
Old February 8th, 2012, 12:51 PM
Matt223081's Avatar
Matt223081
Matthew Scanlon
84 D90 200TDI
keep your eyes on Ebay, I just got one dirt cheap on Sunday.
Old February 8th, 2012, 01:00 PM
Abrooks's Avatar
Abrooks
Tony Brooks
You're kidding!
Old February 8th, 2012, 01:03 PM
Matt223081's Avatar
Matt223081
Matthew Scanlon
84 D90 200TDI
........$50..........
------ Follow up post added February 8th, 2012 01:04 PM ------
shipping is going to cost more than the roll bar
Old February 8th, 2012, 01:05 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Your ebay karma is strong. Very Strong.
Old February 9th, 2012, 10:55 AM
Matt223081's Avatar
Matt223081
Matthew Scanlon
84 D90 200TDI
You win some you lose some, I had a complete used OME HD suspension set up that was won for $95, Im guessing that is where my good Karma came from this time
Old February 17th, 2012, 03:49 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Hi,
Might have what your looking for, am currently converting my D90 into a trail truck with a full trayback. Did have a 3/4" mohair tilt on it over a pair of MOD roll hoops. Let me get them out & I'll post a pic up for you. The front hoop sat behind my truck cab so would work for your application.
Old February 17th, 2012, 03:51 PM
Abrooks's Avatar
Abrooks
Tony Brooks
thanks, I'll look forward to the pictures.
Originally Posted by Landy_Andy View Post
Hi,
Old February 17th, 2012, 07:34 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Here you go.... this is the behind cab hoop :
http://i946.photobucket.com/albums/a...58_640x480.jpg
These are the seat belt brackets that can be bolted on for tilt & then you can take them off for truckcab :
http://i946.photobucket.com/albums/a...63_640x480.jpg
This is the rear hoop & the hood bow parts. I reverse mounted this hoop to give a real strong rear hood frame. It work's out a bit tight for the hoods but they can be made to fit. The hoop has the same stays & brackets as the front hoop with it.
http://i946.photobucket.com/albums/a...59_640x480.jpg
Haven't a clue on what there worth, there not that light so..... pony express would be the best shipping option for you.
PS.... can also take the front hoop mounting brackets out the old tub once I clear the 5' of snow off the top of it !
Old February 17th, 2012, 08:30 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Pm sent, Andy
Old March 13th, 2012, 11:24 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Bump -- anyone brought over an MOD truck with that pesky roll bar taking up space?
Old March 27th, 2012, 12:33 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Getting no love from any of the vendors, either they don't have the MOD bar or Exmoor bar or won't return calls. Any ideas out there?
Old March 27th, 2012, 02:20 PM
Naplm00
Matthew
I just got mine painted and installed over the weekend. Instead of using special cappings i just drilled out the existing and fitted.
I ended up cutting off the seatbelt attachment points, so i could keep the bar on with the truck cab in place. I use lap belts anyway
Old March 27th, 2012, 08:47 PM
Tony, did you try Stephen at Safari HP? He's not always good on email, but may be worth a call...I'm SURE he's got something for you. Roadtrip to FL! You can head there after Uwharrie (read: a good reason for us to go to Uwharrie!).
Old March 27th, 2012, 09:54 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I have, but between issues with the last order I placed and trying to get help with this one unsuccessfully I've given up. It may be time to break down and get something fabricated.
Old March 27th, 2012, 10:51 PM
Justin can get one for you six weeks delivery
mod, roll bar
D-90 Roll Bar Pads roverboy For Sale - Parts 2 November 16th, 2005 10:28 AM
NAS SW entire roll bar kit sheki For Sale - Parts 4 September 30th, 2004 05:28 PM
roll bar end caps mpodgorski For Sale - Parts 2 July 9th, 2004 06:09 PM
Rear roll bar pendy Wanted 0 June 17th, 2004 01:10 AM
Roll bar pads for SW Chaucer Wanted 3 December 3rd, 2003 02:44 AM
» Defender Registry
Vader
cwilder
Sandy
Sandy
Add your Defender
