Marks 4WD adapter - Defender Source
Old December 28th, 2010, 07:34 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Marks 4WD adapter
Looking to see if anyone has a Marks 4WD adapter for mating the TH400 transmission to the LT230 transfer case that they would like to sell.
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old December 28th, 2010, 09:31 PM
rovertrader's Avatar
rovertrader
Dale
Chris- if you can find we could copy and return, I'ld be able to help as I need one as well.
Old December 28th, 2010, 09:50 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I was trying every option before I order from Marks. If anyone knows of an alternative to them I'm interested.
Chris Hinkle
Old December 29th, 2010, 06:40 PM
rovertrader
Dale
the last adaptor we ordered from them took several months- SBC to ZF HP22
Old December 29th, 2010, 10:11 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
I'd love to get my hands on one of the sbc to zf's cheaply lol
Unknown Author
716-898-8153
Old December 30th, 2010, 05:28 AM
rovertrader
Dale
give me a ring, I think we may have a CAD of it:-)
Old December 30th, 2010, 07:50 AM
Chris, talk to Shane at Roverhybrids.com. He and I have been having a similar conversation regarding an NP435 to LT230. He has a 4BT powered 90 that has an NV4500 connected to an LT230. His solution was to have the input gear on the LT230 broached to fit the splines on the NV4500, which he tells me are the same as the TH400 (30 spline I think, which is better than the Rover's 10). He has an aluminum spacer with a seal to fit the new shaft and the proper bolt config for each side. The advantage to this is that the gearbox output shaft is about 20 percent fatter than the Rover spud shaft. It only adds about an inch and a half to the total length and once it has a little dirt on it you'd swear it came from Solihull that way.
Old December 30th, 2010, 11:57 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Thanks, I'll give him a shout and see if we can come up with a US solution to the issue. I really would prefer a 4L80E but had reconciled to use the TH400.
I have a weird desire to cram an E rod crate motor in something!
Chris Hinkle
Old December 30th, 2010, 03:12 PM
IrishRover's Avatar
IrishRover
Sean Lawlor
Chris -
You might give Pendy a call on this as we've been working through a project with this adapter (incomplete). He had to have some part redone.
Sean
Old December 30th, 2010, 04:33 PM
Opening up the LT230 input gear to fit the splines for the 4L80E (electronic? really?) should be no biggie for a shop to do.
Cram away, my friend! USA Power all the way!
Old December 30th, 2010, 05:32 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
You can actually buy a non-electronic 4L80E - plus on the 4L80E is the overdrive. www.transmissioncenter.net/4l80e.htm
Chris Hinkle
Old December 30th, 2010, 05:55 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
you guys might want to check with Eddie at west coast rovers, I believe he has a 400 in his 90 and may be some help with the adapter situation.
Tis
Old December 30th, 2010, 07:27 PM
rovertrader
Dale
Tis is correct, except it is between a 4.6 and an Atlas twin stick. 4.6 to TH400 to Atlas to Dana 60s
Old December 30th, 2010, 11:51 PM
Donny Lang
Donald Lang
D90 clone
Has anyone else tried a quadratrac transfer case out of a late 70's AMC truck? It uses the turbo 400 (Chev or AMC bellousing) and is the same configuration as the 230. It is full-time 4wd and has a center diff that can be locked via a vacuum control. I had one behind a AMC 401 in a J20 for years and never broke anything.
I don't have my D90 hybrid driving yet, but I have the 360/TH400/Qtrac in the frame and it fit like it was made for it. The TH400 is a bit on the long side, though.
Its likely cheaper to find a quadratrac than build the adapter for the LR case.
Old January 1st, 2011, 10:56 AM
Crickets......
I don't think anyone is too keen on a chain drive xbox.
Old January 1st, 2011, 12:43 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I've sent Shane, Pendy and Marks 4WD emails and I'm waiting for replies. Not much else to do.
Chris Hinkle
Old January 1st, 2011, 04:37 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
I may just do that next week, need to see if my free motor is coming through
Unknown Author
716-898-8153
Cigarette Lighter adapter boshea Defender Technical Discussions 17 October 19th, 2007 05:41 PM
Steering Wheel Adapter thelandroverguy Defender Technical Discussions 19 May 8th, 2005 07:16 PM
ARB adapter D110 JackW Defender Technical Discussions 0 March 13th, 2005 10:15 PM
another momo hub adapter question dnewman9 Defender Technical Discussions 0 October 3rd, 2004 08:46 PM
Oil Cooler Adapter O-ring Size dnewman9 Defender Technical Discussions 0 September 5th, 2004 12:30 PM
