Madman EMS2 EGT/Boost/Temp Gauge - Defender Source
Old March 2nd, 2015, 10:37 AM
BlackField's Avatar
BlackField
Oscar
D110
from the site:
Measures 7 inputs, Fully customisable alarms. Unit Only, purchase a kit or loose senders separately.
Exhaust Gas Temperature, Cooland Level, Coolant Temperature, Oil Pressure, Oil Temperature, Voltage, Engine Hours - All with Adjustable Alarms, Through-Panel Mounted.
Unit Sold Loose, Please buy Sender Kits and Components Separately.
$1300? I see group buys bring the price down. I just need 800 of you guys to get in on this with me so I can afford one.
Old March 2nd, 2015, 05:02 PM
myoverlandrover's Avatar
myoverlandrover
josh
109
You sure ?? I bought mine from nata enterprises In Australia and right now there 192 aud or 149$ usd. You need the wiring kit too but that's cheap
Defender 110
Old March 2nd, 2015, 05:29 PM
Not sure where you are looking.... Maybe your currency conversion is off.
MadMan - MadMan EMS2 Unit
R 1760.16 = $150 USD for the gauge. Then whatever for senders.
Old March 2nd, 2015, 05:50 PM
BlackField's Avatar
BlackField
Oscar
D110
I figured I did something wrong. But they do have some group buy incentives if someone wants to spear head that venture I'm in. I'm out as the group buy leader for obvious reasons.
Old March 2nd, 2015, 05:58 PM
the rover shop
shayne young
I'd probably be interested in one..!!.. With all the sensors nec of course..
Old March 2nd, 2015, 06:14 PM
You can see their sensor package kits here: MadMan - MadMan EMS Vehicle Specific Kits
Old March 2nd, 2015, 06:17 PM
BlackField's Avatar
BlackField
Oscar
D110
I'll send them an email to see if they are available and what the timeframe and total cost with all the necessary sending units would come out to.
I promise not to convert the price to New Zealand Rupees or whatever again.
Old March 2nd, 2015, 07:00 PM
myoverlandrover
josh
109
You have to poke around the site too as they have some cool adapters etc that don't come with the normal "kit".
Defender 110
Old November 4th, 2015, 02:20 PM
Any progress on this?
Old November 4th, 2015, 02:47 PM
BlackField's Avatar
BlackField
Oscar
D110
I ordered it. Installed it. Good stuff.
Currently using it for
- volts
- engine hours
- coolant temp
- oil pressure
- EGT
have not connected the boost sender yet but it's installed.
This pic shows what the OEM 200TDi coolant temperature sending unit will display. I ordered the appropriate VDO 150 sending unit and now everything looks to be reading accurately.
Old November 4th, 2015, 02:50 PM
- volts
- engine hours
- coolant temp
- oil pressure
- EGT
Badass. I could reclaim/repurpose alot of my dash with that gauge.
Mark Kellgren
KM4BOR
Old November 4th, 2015, 02:56 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
- volts
- engine hours
- coolant temp
- oil pressure
- EGT
Thats so cool, I will be picking one of these up soon. Hour meter and EGT's 2 birds one stone right there! Glad to see it displays freedom units as well.
Old November 5th, 2015, 03:06 PM
BlackField's Avatar
BlackField
Oscar
D110
Here's a partial list of items I used:
- 5/8-18 UNF to 1/8-27 NPT Gauge Sensor Sender Adapter Reducer (OEM 200TDi to VDO 1/8 NPT)
- VDO 323057 Temperature Sender
- 1/8" NPT STEEL Weld Bung EGT TEMP, PYRO tank fitting low profile MADE IN USA
- M10x1.0 M10 1.0 1/8 NPT Oil Fitting Pressure Tee T Adaptor Volkswagen Turbo
- VDO Oil Pressure and Boost Pressure Sending Units (not sure which part numbers, can't find the order)
Old November 5th, 2015, 03:21 PM
- VDO Oil Pressure and Boost Pressure (not sure which part numbers, can't find the order)
why didn't you go with using the EMS2 for your oil pressure and boost pressure? I can see from the website that it can also read those values.
just curious on your thought process.
Mark Kellgren
KM4BOR
Old November 5th, 2015, 03:23 PM
BlackField's Avatar
BlackField
Oscar
D110
It was the sending units. Corrected the list.
It is reading oil pressure and he said he is hooking up boost......
Old November 5th, 2015, 03:24 PM
Cool that is fits in the stock gauge location. I had not realized it would do that.
Old November 5th, 2015, 03:48 PM
ok thanks. that was what was throwing me. I'm definitely going to get one of these. I have too many gauges now.
Mark Kellgren
KM4BOR
Old November 15th, 2015, 06:18 PM
BlackField's Avatar
BlackField
Oscar
D110
Here are the other sending units I used:
Oil Pressure: VDO 360-025 Pressure Sender: 0-150 PSI/10 Bar - 1/8-27 NPT - 10-180 Ohms - 11.4 PSI WC -$40.45
Boost: VDO 360-043 Pressure Sender: 0-30 PSI - 1/8-27 NPT - 10-180 Ohms - Single - Floating $39.70
Old November 20th, 2015, 06:12 PM
GM13's Avatar
GM13
Gene
'83 110 CSW
Looks like they're out of stock, would suit my needs nicely, drats. Thanks for posting up part numbers.
boost
TDI owners.. Show me your Boost and EGT guages josh-man Defender Technical Discussions 59 December 4th, 2014 08:59 PM
Discovery EGT Gauge Placement smenzel Defender Technical Discussions 3 April 26th, 2013 06:47 PM
Temp Gauge dbwitt Defender Technical Discussions 5 March 18th, 2004 08:14 PM
temp gauge ron Wanted 0 December 10th, 2003 12:44 PM
Temp gauge on H perminently ron Defender Technical Discussions 1 December 8th, 2003 05:27 PM
