M8 X 1.25 Metric Hex Nuts - Defender Source
Old March 28th, 2011, 12:46 PM
The Dro
Dro
1988 Ninety
I'm looking for eight (8) Grade 8 or higher.
I've been everywhere and they only sell 100 Qty packs. Lowe's, HD and the likes, sell Grade 5 or less.
Thanks!
Old March 28th, 2011, 01:05 PM
Odd that they sell them as grade 5 or 8 since that rating system is used for standard thread hardware only. In the metric dept you would be looking for something like class 8.8 or 10.9.
http://www.boltdepot.com/product.asp...5&cs=201&cm=22
Thanks!
Old March 28th, 2011, 01:50 PM
The Dro
Dro
1988 Ninety
You know what I meant... I wrote it without being technical... sorry!
I'm going to keep looking for a local place... shipping is $9 for a .72 order.
Old March 28th, 2011, 03:10 PM
Naplm00
Matthew
have a fastenal near you? They will sell by the piece
Old March 28th, 2011, 04:06 PM
CDeWan
Clay DeWan
5.3L beastie
Matt,
Hopefully. I have 2 Fastenals by me. One they will gladly split open a pack as sell it to you no problem... the other won't. Not sure I understand why there is a difference in their store policy. But yes I agree it is a great place to pick up hardware especially if it it stainless as I have replaced most of the nuts and bolts in stainless and you can't beat $11 - $14 for bag of 50 SS bolts or nuts.
Clay
Old March 28th, 2011, 04:22 PM
The Dro
Dro
1988 Ninety
There are two, neither will break a package. Plus a Graybar, Grainger, HD, Lowes, AdvanceAuto, AutoZone, PepBoy's... none have it.
Old March 28th, 2011, 04:41 PM
mattdh's Avatar
mattdh
Matt Hurst
ace hardware will have them
Old March 28th, 2011, 08:07 PM
CDeWan
Clay DeWan
5.3L beastie
Pedro,
We have a place called Marshalls and they sell everything. I can check....what length are you looking for?
Clay
Old March 28th, 2011, 10:07 PM
The Dro
Dro
1988 Ninety
Clay,
I appreciate your help.
I'm hoping Loic has some...
If not, I'm biting the bullet and will buy the whole bag at Fastenal, it was around $15-20 for the 100 Qty bag.
Old March 28th, 2011, 10:10 PM
CDeWan
Clay DeWan
5.3L beastie
o.k. just pm if you need help.
Old March 29th, 2011, 12:26 AM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
I second the Ace Hardware. When I first started my rebuild project I went around with a double sided 8.5x11 sheet of paper full of bolts that I needed listed out. I found only a small portion of them at Lowe's, Home Depot, etc. The Fastenal here will not sell small quantities. There is a local outfit here called DD Bolt that is great but still prefers to sell in bulk. I went to the Ace in the next town over and they had every single bolt on my list except one. Ace is the place!
Old March 29th, 2011, 03:40 AM
TS888's Avatar
TS888
Tony Sims
1984 110
X3 on Ace. Best selection of metric or SAE hardware, by the piece. I miss them greatly, the best I can do in the UK is a place called Screwfix, and I end up buying in bags of 20 or 50. Of course on my 110, that's not a problem since every fastener has to be removed with the angle grinder...
Tony
1984 110 "Smokey" (sold)
Old March 29th, 2011, 01:11 PM
The Dro
Dro
1988 Ninety
Loic had some... thanks all for the help.
M8 1.25 90mm flanged bolt Retrofit Wanted 0 August 5th, 2007 03:54 PM
Quick-release nuts for door tops - can anyone remember these? chittybangbang Defender Technical Discussions 20 May 30th, 2005 10:57 PM
hub nuts jimmy salmon Defender Technical Discussions 2 March 13th, 2005 06:00 PM
Rear spare tire mount - nuts Kimos Wanted 1 December 4th, 2004 08:17 PM
Lug Nuts!!! Get loose today !!!! Vadim Defender Technical Discussions 10 October 26th, 2004 03:58 AM
