LT77 shifter assembly needed - Defender Source
Old November 2nd, 2014, 03:56 AM
Apocalypse Vehicle
Evian Degree
none yet
I'm looking for a shifter for an LT77 transmission that I'm putting into my series. I've got the tranny but I need the complete shifter mechanism...........Thanks
Old November 2nd, 2014, 05:28 AM
rgrrvr's Avatar
rgrrvr
DJ Menasco is The Dude
1995 D90
Is it radically different from the R30 shifter? I have one of those
...you'll feel better in a couple of days.
Old November 2nd, 2014, 07:13 AM
the rover shop
shayne young
If I recall correctly R380 disco is different from defender but lt77 defender to r380 defender is the same.. I know when I do an lt77 to r380 conversion I have to use the lt77 tranny.!!
Old November 2nd, 2014, 07:53 AM
Someone like Rovertrader probably knows the answer!
Old November 2nd, 2014, 08:47 AM
shift levers interchange between r380 and lt77. The shift towers on the transmissions are very different. If you just need the stick that should be easy.
Old November 2nd, 2014, 09:47 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I am curious on this as I have a LT77 in the runner and a shorty R380 on the new chassis and thought the LT77 top shifter linkages would bolt right up.
Doing some searching I've found:
FRC7155 as the gear lever housing (looks to be the same between the LT77 and R380.
FRC8724 is the gear lever lower. My parts catalogue PDF says the same number from both but it comes up on the UK order companies as LT77 only.
There are springs and seals but they seem to be small and work for both.
Is there a different part number for the lower lever for the R380? If so any idea what it is?
ID:	106178   Click image for larger version
Old November 2nd, 2014, 02:04 PM
Apocalypse Vehicle
Evian Degree
none yet
You know maybe I can piece this thing together. I don't need the transfer case gear selecting part because I'm running the ashcroft kit that links my series transfer case to the lt77. I just need the complete lt77 shifter assembly with housing, gear shift lever and whatever else it includes.
Old November 2nd, 2014, 02:40 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You're correct.
If you are swapping a short LT77 for an R380 stumpy in a Defender style vehicle, the main gearbox tower moves right over onto the R380 and works fine.
RDavisinVA
Old November 2nd, 2014, 06:40 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by rdavisinva View Post
You're correct. If you are swapping a short LT77 for an R380 stumpy in a Defender style vehicle, the main gearbox tower moves right over onto the R380 and works fine.
Thanks Robert - one less thing that i will have to buy.
Old November 2nd, 2014, 06:44 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
The LT230 T-case linkage however will likely be different.
RDavisinVA
Old November 2nd, 2014, 07:41 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Figures... Will have to figure that one out.
assembly
New Shifter Boot LT77 Rosproline157 For Sale - Parts 6 January 27th, 2013 07:21 PM
Free LT77/LT230 + Shifter + Brake mattarm For Sale - Parts 9 September 14th, 2012 04:40 AM
Need an LT77/LT85 Shifter Knob Wolf Fabrication Wanted 3 February 15th, 2010 09:11 PM
LT77 Shifter Knob Rugbier Defender Technical Discussions 3 November 3rd, 2009 04:35 PM
For Sale Shifter Assembly Brand New in box Discovery 1 or 1997 Defender $75 nosivad_bor For Sale - Parts 9 August 24th, 2009 03:27 PM
