LT77 or R380 wanted - Defender Source
Old May 4th, 2013, 09:13 AM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
LT77 or R380 wanted
Anyone one in the New England area have a an LT77 or R380 tans for sale ( in good working order)
Thanks in advance
Chris "V"
Old May 4th, 2013, 09:41 AM
V8 or 4 banger would be helpful to know.
Old May 4th, 2013, 09:50 AM
And Defender or Disco....
Old May 4th, 2013, 12:40 PM
Chris Velardi
Chris Velardi
1975 101FC
Defender without spark plugs ;-)
Chris "V"
Old May 4th, 2013, 01:47 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
That narrows it down to 8 different transmissions?????
There is the 200TDI long or short bellhousing unit for the defender (2 different)
200TDI long or short bellhousing unit for the discovery (2 different)
300TDI long or short bellhousing unit for the defender (2 different)
300TDI long or short bellhousing unit for the discovery (2 different)
Which are you looking for??????
RDavisinVA
Old May 4th, 2013, 03:51 PM
Chris Velardi
Chris Velardi
1975 101FC
any will work I will remove the bell housing off the original trans
Chris "V"
Old May 4th, 2013, 04:39 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
So what engine do you have and what transmission do you currently have? Say you have a short bell housing lt77 and you have a 200tdi. While you can technically use a later style 300tdi long bellhousing r380 trans, not only would you need to use the long bell housing that comes with that transmission (the input shaft is longer) but the engine would also need to be mounted forward of the normal 200tdi position. If you have a short bell housing trans now, that's what you will want to stick with. So what do you have?
Old May 4th, 2013, 06:31 PM
He could be planning on using it in his 101....which is another combination all together...
Old June 11th, 2013, 05:26 PM
JSQ's Avatar
JSQ
Jack Quinlan
I have a good defender diesel R380. I think it's L suffix but I'd have to check.
r380, wanted
R380 and LT77 Gearboxes OBXrover For Sale - Parts 5 December 6th, 2012 09:41 AM
LT77 or R380? MAX711 Defender Technical Discussions 3 October 1st, 2010 02:29 PM
Wanted: R380 or LT77 for project Coiler Wanted 8 March 9th, 2010 12:38 PM
LT77 crapped out on 200Tdi - swap in R380 ? metric Defender Technical Discussions 8 June 11th, 2008 11:58 PM
UK rebuilt LT77 R380 FS SafariHP The Vendors Loft 0 June 11th, 2008 05:46 AM
