LT77 LHD Seatbox and NAS 110 cage corner post. - Defender Source
Old May 27th, 2010, 10:26 PM
madcowdungbeetle
Carter
I'm looking for a seatbox from a LHD Defender that had an LT77 transmission. The seat box can be any color, but must be in good to like new condition, no rust at all.
Also looking for a passenger side rear corner post for a NAS cage. This is the portion that is in the rearmost corner of the body that the rear portion of the external cage bolts through the tub to as well as the jumpseat mounting.
If you have what I am looking for please PM me.
Thanks!
Old May 30th, 2010, 05:23 PM
madcowdungbeetle
Carter
Still looking
Old May 30th, 2010, 06:20 PM
Mike at ECR can get the SD parts for the cage...
Old May 30th, 2010, 11:52 PM
The LT77 will fit under the same seatbox and tunnel as the r380, so pretty much any seatbox that was on a relatively modern defender will work for you. Unless you have something else in mind.
Old May 31st, 2010, 07:23 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I have the extra cage parts.......
Matt Browne
Old May 31st, 2010, 10:40 AM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
I have a seat box out of a 1983 or so ROW 110 that I need to get rid of.
Probably not in as good condition as you want but there is only minor surface rust.
Here are some photos. I really want to get this out of here so I am sure the price will be right whatever that will be?!
Tyler
ID:	28132   Click image for larger version
Old May 31st, 2010, 12:21 PM
bcourtney's Avatar
bcourtney
Robert Courtney
1973 Series III 200TDI
I recently bought a used seat box. It had some rust on the battery box, so I removed it sandblasted and had it LineXed. Those boxes are really heavy weight so don't be scared away by some rust.
Old May 31st, 2010, 01:39 PM
madcowdungbeetle
Carter
I'm not afraid of surface rust, however, I'm trying to be as explicit as possible as to what I'm looking for. I do not want to deal with even the slightest hint of rot or repair, I already have enough of that to deal with.. For my personal trail truck I would not care, but this is for a frame off NAS110 restoration.
Old May 31st, 2010, 02:07 PM
My NAS 110 had a standard r380 seatbox, and a bulkhead to match...
Need pix?
Old May 31st, 2010, 03:00 PM
madcowdungbeetle
Carter
Need pix?
Couldn't hurt. I guess I was operating under the false assumption that if it had an LT77 transmission, it would have been LT77 throughout.
Thanks Jim
Old May 31st, 2010, 11:24 PM
Thanks Jim
I thought the same thing. The only thing you have to watch is the shape of the opening in the bulkhead. If you are replacing the bulkhead and have a new Td5 one on hand, you are probably OK. Worst case you just have to get the right adapter flange if you have some older or different spec bulkhead.
Old May 31st, 2010, 11:47 PM
Ren Ching had a very good post explaining the different seat box/tunnel covers.
Old June 1st, 2010, 06:56 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
I've failed Carter on my search for the missing corner post.......search ON.
Matt Browne
Old June 1st, 2010, 08:03 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Carter, what is wrong with the old seat box, If its the sides, I once purchased new aluminum side pieces and rebuilt the seat box to like new...
Legend in My Own Mind.
Old June 1st, 2010, 01:18 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Makes sense. You do not want mine then.
Worth a try.
110, cage, lhd, nas, nas 110
Rebuild and Tdi Conversion Pix JimC Truck Build-up's & Restores 9 January 10th, 2012 04:58 AM
NAS 110 Rolling Chassis and HCPU body parts surf110 For Sale - Parts 5 September 8th, 2009 01:51 PM
NAS Seatbox, floor , carpet etc FS SafariHP The Vendors Loft 1 May 9th, 2008 02:07 AM
