Lt77 for a series 200tdi project - Defender Source
Old January 4th, 2015, 01:42 PM
nfbeckman's Avatar
nfbeckman
Nick Beckman
1996 Disco 300 TDi 5speed
Looking for an lt77 for a project. Anybody?
1996 Disco 5speed 300tdi
Old January 4th, 2015, 02:05 PM
You need to ask a few more questions.....
Do you want a Disco/RR or Defender box?
Do you want the LT77 or LT77S? They have different ratios. The LT77S that came with the 200TDI has better ratios for the engine, IMO.
Are you concerned over which suffix box you get? There are large strength differences from early to late. You really want and "F" or later if you want it to last behind the 200TDI.
Old January 4th, 2015, 02:55 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
I have one needing a rebuilt (ashcroft can supply everything). Shipping will be expensive but... If needed send me an email.
Old January 4th, 2015, 04:38 PM
nfbeckman's Avatar
nfbeckman
Nick Beckman
Thanks for the input. I'm not in any way familiar to the 200tdi gear boxes. My project is a 1974 series III 109. I've got a brand new 200tdi that I purchased to swap in.
So I guess I'll need the defender version. And as new as I can find as far as strength of the different boxes.
Old January 4th, 2015, 06:06 PM
nfbeckman's Avatar
nfbeckman
Nick Beckman
I guess an r380 for a diesel defender would be good also.
Old January 4th, 2015, 06:18 PM
Ashcroft "stumpy" R380 is about $1500 delivered to you.
Old January 4th, 2015, 07:10 PM
If you are doing a series conversion you could use many things. There is a lot of custom work either way and you need to understand what you want to do. The best option would have been to get the box and transfer case that were with the engine. Is it a defender or disco 200tdi? This is probably not the best board to find a good diesel LT77 as none were on North American trucks. Safest bet is to bring in a rebuilt one.
Old January 4th, 2015, 07:42 PM
nfbeckman's Avatar
nfbeckman
Nick Beckman
The engine I have was never installed. It's nos defender 200tdi that was complete from the fan clutch to the pressure plate. I'm prepared to do a lot of fab work to fit it, but I need to find a tranny first. Otherwise I am goin to just adapt it to the stock series 3 box. But I've read that they won't hold up.
Old January 4th, 2015, 07:52 PM
The series box will go boom.
What transfer case are you using and what gearing as this affects the choice? What are you doing with the axle gearing? This all needs to be thought of together.
Strength wise you want an F or later suffix LT77 or an R380. The defender version will be better for placing the shifters. I'm not sure if short or long bellhousing makes a difference. You would need to talk to people that have tried it. Clearance to the tunnel and seat box are the concerns.
Old January 4th, 2015, 07:55 PM
Also, IMO, there is no point to a used box unless you are rebuilding it. These are not bulletproof and a 20 year old used piece is just a time bomb.
Old January 4th, 2015, 07:58 PM
nfbeckman's Avatar
nfbeckman
Nick Beckman
I will be swapping to toyota 4.10 axles and using a 1.2 lt230 transfercase. I'm going to construct a new tunnel cover once the drivetrain is in place.
I've got a discovery v8 r380, what would I need to use it?
Old January 4th, 2015, 08:08 PM
Rebuild the box with diesel input shaft and then add a diesel bellhousing and all the throwout parts. You could go short or long.
The shifter will be in the seat box or you could rebuild with defender shifter parts as well to get them in the correct location.
The V8 first gear will be a bit high so you could also change to the diesel first gear.
That or buy a rebuilt ready to go diesel defender box.
Old February 6th, 2015, 04:19 PM
couga861900's Avatar
couga861900
Cougar, WM of Hiram 72
Land Rover Defender 90 2.5td
Who sells rebuilt gear boxes?
Old February 6th, 2015, 05:00 PM
http://www.ashcroft-transmissions.co...gearboxes.html
Old February 6th, 2015, 05:19 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I have a 70K mile very solid LT77 and a part-time transfer case that IMO would be perfect for a Series conversion.
PM me if interested.
Clay
Old February 13th, 2015, 06:57 PM
couga861900
Originally Posted by 1of40 View Post
I have a 70K mile very solid LT77 and a part-time transfer case that IMO would be perfect for a Series conversion. PM me if interested. Clay
Clay, I just sent you money.
200tdi, series, tdi
My current project; Project 90-3 diesel_jim Truck Build-up's & Restores 2 June 15th, 2013 04:22 PM
My British car project for your British Series project? corrigan For Sale - Vehicles 9 April 27th, 2013 02:10 PM
My current project; Project 90-3 diesel_jim Truck Build-up's & Restores 5 April 23rd, 2012 06:32 AM
Wanted: R380 or LT77 for project Coiler Wanted 8 March 9th, 2010 12:38 PM
LT77 crapped out on 200Tdi - swap in R380 ? metric Defender Technical Discussions 8 June 11th, 2008 11:58 PM
