LT230Q transfer gearbox - Defender Source
Old May 29th, 2014, 06:18 PM
Talleyrand's Avatar
Talleyrand
1998 Defender 110 CSW 300Tdi
Need a transfer gearbox to mate with a Defender R380, with 1.222 gear ratio instead of the usual 1.4. Any suggestions for vendors also most welcome.
Cheers,
Old May 29th, 2014, 06:38 PM
Contact your local salvage yard and get one off a D1.
Old May 29th, 2014, 07:19 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Pretty sure D1 is not a Q box they were in the DII but to use a DII is not as simple as the DI box.
Just go with the standard 1.2 DI box it might not be as quite as the Q box but easier to fit and less
Old May 29th, 2014, 07:24 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
D1 LT230s from about mid 1996 had the "Q" fine cut gears. This will be your easiest approach. Find a D1 box and remove the interlock solenoid.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old May 30th, 2014, 12:08 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I have a LT230 sitting in the back of my Series and not sure where it came from and if it is good. I think it has to be a 1.2. I can check this weekend.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old May 30th, 2014, 02:45 AM
Thanks for the year clarification, Dave.
Old May 30th, 2014, 10:56 AM
Ray_G's Avatar
Ray_G
Ray Gerber
As Rob alluded, about mid 96 on you can find them in D1's; I am certain of this because my 97 XD has one in it that I'm saving to retrofit into my 96's standard gearing.
R-
Ray
Old May 30th, 2014, 11:20 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
If the disco it came out of has a rotoflex coupling at the rear diff, then it wasn't built with a Q box
If it has a u-joint rear shaft, then it was
but be advised the earlier boxes are sometimes swapped into these trucks, and vice versa as the Q boxes can be found installed as replacements on the earlier models. Easy way to tell is with a non fully splined spud shaft as go/no-go tool you can only fit "just the tip" into a q box. (its a real bitch to find this out under a truck while holding a tcase over your head)
LT 95 gearbox..do I have to remove gearbox from truck to replace reverse idler shaft? Ncmike Series Technical Discussions 3 April 13th, 2014 03:33 PM
LT230Q weight? RoverC Defender Technical Discussions 6 May 25th, 2009 04:47 PM
97 Lt230Q for sale RoverC For Sale - Parts 8 May 24th, 2009 10:09 AM
Where can I buy LT230Q parts? Hammertime Defender Technical Discussions 2 May 24th, 2009 07:49 AM
ZF4HP22 and LT230Q t/c RoverC For Sale - Parts 3 June 24th, 2008 08:30 PM
