LT230 with 1.4 gears or just the 1.4 gears!! - Defender Source
Old May 13th, 2011, 05:40 PM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
So I figured out that I have a 1.6 LT230 transfercase as I almost exploded the engine trying to hold 65 mph actually it did well except the whole superheated cubby box over the t-case. So I looking for
1. Adice
2. parts to accomplish said advice
1. do I swap the high range gears with the Ashcroft kit and just put 1.4 gears in (if so how hard is this to do?)
2. get a whole t case with the 1.4 gears? i realize that this is easier so with that in mind does it matter if it's a disco vs defender lt230? My truck is a Defender 110
Any advice is appreciated.
Old May 13th, 2011, 06:10 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
well - I have a used 200tdi 1.4 ratio LT230 from a 1992 sitting here in good shape as far as I can tell. Some interest in it - but has to be shipped. You're close, so you wouldn't have to deal with that. Fairly easy swap. You running a diesel? I couldn't handle the lack of power with the 200tdi even with 1.4 ratio (on california highways) so I'm going big.
of course, getting the 1.4 gears and a re-build kit from ashcroft gets you a rebuild vs. throwing in a used one.
The disco cases work(I'm putting a 1.2 in my truck now), but you have to dis-able/remove the park solinoid thing. I think most of them are 1.2 ratio.
Old May 13th, 2011, 07:32 PM
El Solis's Avatar
El Solis
Chris Solis
yes i'm running a 200tdi diesel, i moved to livermore so even closer. now you've got me thinking even more, why going with the 1.2? i have a CT110 from 89 and don't really need to go faster than 65-70 to be honest and hopefully pull 55-65 up some hills to tahoe now and then. what would you want for your t case?
thanks
Old May 13th, 2011, 07:56 PM
16kpsi's Avatar
16kpsi
Tony Lawson
email sent
lt230
Feeler post: D110 axles, Salsbury & 1.4 LT230. Roving Beetle For Sale - Parts 4 April 26th, 2010 02:06 PM
LT77 and 1.4 high range LT230 evilfij For Sale - Parts 15 April 26th, 2007 12:06 PM
Gears vs Tires jimbemotumbo Defender Technical Discussions 21 April 26th, 2005 09:23 AM
3rd Members with 4.75/ARB's and LT230 billnsandi For Sale - Parts 0 January 26th, 2004 11:29 PM
4.10 gears and Detroit locker dave_lucas For Sale - Parts 3 December 1st, 2003 03:03 PM
