lt230 tcase mount rhs (disco lt230) - Defender Source
Old October 11th, 2015, 02:01 PM
Cajun
G
1987 110
Need the mount for the tcase side not the frame side. Here's dims for mount attached. This transfer case is from a 2004 D2.
Old October 11th, 2015, 06:52 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
There are two, and different per application. What is this going in? Is it a manual/automatic if manual lt77/r380
Old October 11th, 2015, 10:58 PM
Cajun
G
1987 110
it's going in an 84 110 that previously had an lt95. I'm doing an ls swap so it's mounted to the 6l80e. assuming the lt77/r380 variant would work.
Old October 11th, 2015, 11:12 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
This is the mount on the transfer case side to the frame. There is also a mount that ties into the transfer case with a rubber engine mount in between them. This mount is actually close but not the actual defender one, I believe this came off a RRC. The only difference is on the left side there is no lip it is flat, but over all dimensions are the same.
Old October 11th, 2015, 11:18 PM
Cajun
G
1987 110
I have that frame side mount shown or very similar. I need the isolator mount that I assume is attached to a 4 hole brkt that mates to the tcase.
Hope I'm making sense. Haven't slept much!
Old October 11th, 2015, 11:33 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Gotcha those should all be the same
Old October 12th, 2015, 10:16 PM
Cajun
G
1987 110
finally found a pic. I need part 2 in this diagram. nrc8204. I already have a new mount.
Old October 14th, 2015, 02:21 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Still looking? Drop me an email if so.
buckhornimports@gmail.com
Old October 14th, 2015, 06:30 PM
Cajun
G
1987 110
email sent. thanks
Disco Tcase in Defender 200tdi Naplm00 Defender Technical Discussions 21 May 31st, 2011 11:45 AM
Disco 1 Tcase Naplm00 Wanted 5 April 29th, 2011 01:29 PM
Disco Tcase to LT77 Naplm00 Defender Technical Discussions 21 April 4th, 2011 05:21 PM
3.9 V8, hp22 ZF trans., lt230 tcase (1.2), early Defender seats tommyd For Sale - Parts 9 February 11th, 2009 12:54 AM
tcase for sale vlocci For Sale - Parts 5 May 25th, 2004 07:14 AM
