LT230 Shift Linkage - Defender Source
Old July 19th, 2015, 10:24 AM
Cajun
G
1987 110
LT230 Shift Linkage
Swapped out LT95 in 110. Have no linkage for LT230 case.
Old July 19th, 2015, 09:23 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
What did you put in? 95/77/r380 all use different linkages for the cdl. Let me know and I have everything for you.
Old July 20th, 2015, 12:03 AM
Cajun
G
1987 110
I put in a 6.2L 6l80e mated to the lt230 with Nick's kit.
Old July 20th, 2015, 12:17 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
You need to order the linkage from nick, from what I understand you have to use his extended arm. Pretty cool build...
Old July 20th, 2015, 03:20 AM
Cajun
G
1987 110
Sorry. I wasn't exactly clear. I need the top side shifter that mounts into the bracket. I need the pieces above the yellow line. I already have the FRC8558 which is the piece below the yellow line and nick's lever.
Name:	lt230 shifter linkage top side.jpg
Old July 20th, 2015, 07:16 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I've got this. PM me if you still need it. I'll post a pic ASAP.
Old July 20th, 2015, 01:56 PM
Cajun
G
1987 110
Clay took care of me. Thanks again!
LT230 shift linkage piece don Wanted 4 November 20th, 2014 10:36 PM
WTD: Shift Linkage LT230 Defender Style R380 rdavisinva Wanted 4 September 2nd, 2014 12:34 PM
LT230 shift linkage eye bolt michael67 Wanted 0 December 17th, 2011 07:59 PM
Adjusting R380 linkage--hard to shift to 3rd Davis Defender Technical Discussions 6 April 22nd, 2010 12:14 PM
LT230 locking linkage needed pcarey Wanted 2 July 23rd, 2007 01:11 PM
