LT230 input gear - Defender Source
Old March 14th, 2018, 03:21 PM
LT230 input gear
Looking for an LT230 input gear, prefer used. splines can be worn. Not looking to pay a lot. Doesn't need to be cross-drilled. Old and dusty originals are fine. Just needs to work.
Does anyone have anything sitting around they want to get rid of?
I don't care about the ratio. Would prefer not to have a Q-type input gear.
I'd actually like to have both an A/B suffix and a C suffix input gear (long and short).
thanks in advance!
Old March 14th, 2018, 04:08 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
Hey Ed,
If you can't find the gear I have a complete good working LT230 in my shop out of a 95 D1 I would part with. I have $350 in it. You can have it for that plus shipping. If you're interested I can shoot you the serial # tomorrow. Just let me know
Cheers,
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi 5 speed SoftDash (My Son's)
"Be the person your dog thinks you are"
Old March 14th, 2018, 04:09 PM
speedpin's Avatar
speedpin
Looking ;)
Ed. I got a good non drilled. Text me.
~ Semper Fidelis ~
Old March 14th, 2018, 05:43 PM
NADA
thanks in advance!
hmmmmmmmm....begs the question......what is the professor up to?
Old March 15th, 2018, 07:02 AM
Hahah! You know me too well, sir
But in truth, I'm not up to anything until I get some of these parts designed. However, if it all starts to come together the way I think it should/would, I'll be posting the results quite openly.
Adam, thanks for responding - I don't have your cell phone number , so I sent you a private message.
Old March 15th, 2018, 07:31 AM
speedpin's Avatar
speedpin
Looking ;)
Ed, PM replied, dug it out last night, should be what you need.
~ Semper Fidelis ~
Old March 15th, 2018, 09:55 AM
NADA
If Adam doesn't have it - I gave one to Grumpy Bill
Old March 17th, 2018, 07:29 AM
thanks Jonesy!
I'm just looking for the stock worthless input gear, nothing special input splines can be worn, it doesn't matter.
Old March 17th, 2018, 09:30 AM
ezzzzzzz
Mark Garrenton
If you're still in need I have one that won't get used here.
I need to go back to work for the break. Retirement is exhausting!
'71 IIA 88" LS1 hybrid
'84 110 5 door 'Nigerian Princess'
'90 RRC
'97 D1 LSE (parting out)
'02 D2 Kalahari
'02 D2 SE
'02 D2 SE
Old March 19th, 2018, 11:45 AM
SLO Hybrid's Avatar
SLO Hybrid
Nathan Harrison
95 25th RRC/94 LWB /04 L322/87 RRC
I have a few early RRC non drilled also (both of them have shagged splines)
lt230
200Tdi and LT230 Gear Ratio Question newfD90 Defender Technical Discussions 33 June 1st, 2016 01:30 PM
Tips on Swapping out the T-Case input Gear? LRNAD90 Defender Technical Discussions 2 April 23rd, 2009 04:14 PM
output shaft spline wear ZACHASS Defender Technical Discussions 8 February 3rd, 2009 03:01 PM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 12:56 PM
LT230 Input gear again! Mike Hippert Defender Technical Discussions 17 June 19th, 2005 05:45 PM
