Lost key help. - Defender Source
Old April 7th, 2011, 12:23 PM
BadMonkey's Avatar
BadMonkey
Nathan
1994 NAS
Lost key help.
Lost my original and the spare isn't working at all. How do I get a key made? I've got the local dealer checking into having one VIN made in NJ, but they're not even sure how long that would take etc. Anybody have any thoughts on this?
Old April 7th, 2011, 12:31 PM
The Dro
Dro
1988 Ninety
What truck do you have?
Old April 7th, 2011, 12:37 PM
BadMonkey's Avatar
BadMonkey
Nathan
1994 NAS
This is for a 94 D90 ST NAS
Old April 7th, 2011, 12:41 PM
what's wrong with the spare?
Old April 7th, 2011, 12:49 PM
BadMonkey's Avatar
BadMonkey
Nathan
1994 NAS
Not sure. It's never worked and to be honest I'm not even sure that it starts this vehicle. It hasn't mattered until now. Brought it over to the hardware store and had them buff out out good because it was sharp-new. Thought that might do it, but nope. Any tricks I might try? It is sometimes a ass to get the steering lock undone, but I feel like I'm just going to twist the key right off with this spare.
Old April 7th, 2011, 12:55 PM
The Dro
Dro
1988 Ninety
When I did mine, I removed the cylinder from the steering column and filled the "locks" with the key in place.
The process to remove the cylinder is a PITA, but not hard.
The key that the dealer will give you most likely will not work. As the cylinder internal are also worn.
Old April 8th, 2011, 02:26 AM
BadMonkey's Avatar
BadMonkey
Nathan
1994 NAS
Original key located behind file cabinet. Thanks for the advice, but I'm glad I didn't have to use it.
Old April 8th, 2011, 07:02 AM
The Dro
Dro
1988 Ninety
Good to see that you found it...
Old April 8th, 2011, 07:22 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Glad you found it -- may be a good opportunity to replace the lock assembly with a new one that has 2 keys with it.
Old April 8th, 2011, 09:03 AM
He has the working key now so surely he can get a spare made now?
Originally Posted by pendy
I'm here for the D's
Old April 8th, 2011, 09:58 AM
The Dro
Dro
1988 Ninety
He can have the spare "re-filled"... sometimes the machine will leave metal shavings and they need to polish it.
Lost key to locking gas cap...HELP!!! tebby Defender Technical Discussions 13 November 23rd, 2009 05:53 PM
Locking Lug Nuts -- Lost the key! chris snell Defender Technical Discussions 5 August 20th, 2006 08:33 PM
replacing ignition key - 94 snosrfr Defender Technical Discussions 10 June 1st, 2005 01:41 AM
Dumb ignition/door key question, did search first Neo Defender Technical Discussions 15 May 30th, 2005 07:10 PM
110 roof, ignition key code, windshield frame, etc... martym Defender Technical Discussions 7 February 24th, 2005 01:45 PM
