Looking for steel gunwall body cap - Defender Source
Old May 4th, 2004, 12:58 PM
GollyGwagen's Avatar
GollyGwagen
Chuck Henry
1982 MB Gwagen
I don't know what else to call it, but the steel (about the only steel bodywork!) cap that trims out the top of the body where the alum stops and the soft top starts. It's a c-channel molded piece.
Anyway, if someone has any sections of this at all I would like to buy it from you. I don't care about condition, it can be all rusted out I just need it for test fitting.
Thanks in advance for any help that can be offered!
Chuck Henry
www.gelaendekraft.com
Old May 4th, 2004, 01:39 PM
Hey Chuck, Just moved the thread as it's more of a Wanted then a need for help. Have you tried RDS, or are you just looking for one that someone has?
Old May 4th, 2004, 01:45 PM
GollyGwagen
Chuck Henry
1982 MB Gwagen
Yeah, of course no one ever comes to this section so I probably won't find someone with a cast off. I was just hoping someone had an old part laying around from a replacement or something.
I guess I can always buy one from the dealer.
Chuck Henry
Old May 4th, 2004, 01:47 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Chuck, give George at Roversdownsouth a call. He should have some cast-offs laying around and ill be much more fair than the dealer.
Old May 4th, 2004, 01:48 PM
GollyGwagen
Chuck Henry
1982 MB Gwagen
Thanks, I'll give him a try.
Chuck Henry
body
Gas cap pulled away from body panel Krna Defender Technical Discussions 9 November 12th, 2009 01:13 PM
130 Hi Cap Body Parts FS SafariHP The Vendors Loft 0 December 18th, 2008 10:37 PM
lifting the body (not plastic surgery :-) cbass Defender Technical Discussions 11 April 25th, 2005 12:14 PM
body work on aluminum mattdh Defender Technical Discussions 11 July 4th, 2004 02:47 PM
radiator cap 97 jorge Defender Technical Discussions 2 November 7th, 2003 09:12 AM
